MK902 - KitKat 4.4 - SMIC717394 ---- 1080p and 720p ROMs
Re: MK902 - KitKat 4.4 - SMIC717394 ---- 1080p and 720p ROMs
Originally posted by INFIN1TY View PostFor all your computer problems...
http://www.salvamipc.es
Originally posted by smic717394 View PostNo even better, on the last version there ia a new button subtitles
Oh that sounds awesome. I havent updated yet I saw I saw there was one. I don't like the permissions they want and also eset reports it as a treat. (even though my box is just media/movies and a fake email) so nothing personal on it. Maybe ill update it tomorrow when I get back home
Originally posted by INFIN1TY View PostOh that sounds awesome. I havent updated yet I saw I saw there was one. I don't like the permissions they want and also eset reports it as a treat. (even though my box is just media/movies and a fake email) so nothing personal on it. Maybe ill update it tomorrow when I get back homeFor all your computer problems...
Originally posted by smic717394 View Postwhy would you even bother with a antivirus?on android the viruses like to steal contacts and send expensive sms, on the mk902 they cant do neither.
Didn't know ;D
I am a WP user 😋 and ofc android tv box. I Saw eset and just installed it I like eset it on my PC as well. It's really useless?
Originally posted by INFIN1TY View PostDidn't know ;D
I am a WP user 😋 and ofc android tv box. I Saw eset and just installed it I like eset it on my PC as well. It's really useless?For all your computer problems...
Check page one for the updated kernels. Thank you.For all your computer problems...
Hey smic while you are fixing things, I think I discovered a small issue in the build.prop which could lead to slightly degraded network traffic.
There seems to be a couple of extra spaces in...
net.tcp.buffersize.default
net.tcp.buffersize.wifi
Its no problem, its easy to fix and it really does not cause much of a difference anyway.
Still its something you should check.
Originally posted by skivit View Postsilly question time, is it better to re-flash ROM and kernel, or just kernel?For all your computer problems...
Originally posted by KingSombra View PostHey smic while you are fixing things, I think I discovered a small issue in the build.prop which could lead to slightly degraded network traffic.
This two like are ok like this, I know it look strange but its ok...
net.tcp.buffersize.wifi=4096,87380,256960,4096,163 84,256960
net.tcp.buffersize.default=4096,87380,256960,4096, 16384,256960For all your computer problems...
Open VPN issue
Many thanks for all the effort!
I'm using this rom now for a few weeks and all fine. Except for an annoying issue with Open VPN.
But to be honest I've no idea if this is related to this rom, kernel, Open VPN itself or the TUN driver.
I did not try VPN with the original Jellybean version. I did quite some searching around but did not manage to find a solution. The internal VPN in 4.4.2 appears to have some bugs making the VPN useless.
What happens is that the box reboots on disconnecting VPN. (MK902 3088)
Another question: I need to reinstall the TUN driver after every reboot. Is it somehow possible that the TUN stays installed?
Thanks in advance.
There are currently 2101 users online. 1 members and 2100 guests.
