MK902 - KitKat 4.4 - SMIC717394 ---- 1080p and 720p ROMs
I installed version 2 of this rom and now it is working again but the camera is upside down and I no longer have 16gb internal memory and now have 8gb, I fumbled my way through the install and dont really know what I am doing can someone advise which file(s) I need please, also Firefox keeps crashing on this site and I have to restart it.
Originally posted by smic717394 View Post
I have installed V2 of this rom and I see the kernel does not have tun.ko module included (so I cannot use apps like OpenVPN, hola.org, etc).
If I try Tun.ko Installer app, I can establish a vpn connection, but when I disconnect vpn the device reboots.
Would it be possible to have a kernel with a working tun.ko module installed ? Or is there any other solution ?
Thanks.
Thanks.
Same issue here. This is not a fault in this rom but as far as I understand a poor implementation of VPN in Kitkat 4.4.2 which has been resolved in 4.4.3.
This applies for both the build in VPN service and external ones based om Open VPN and there is no solution for it.
As this rom and the stock version of Kitkat 4.4.2 did not work for me I reverted back to rooted Jellybean stock firmware.
The issues I had: Netflix audio/video way out of sync and the box rebooted 2 or 3 times a day. The Jellybean works great for me and is 100% stable.
Regarding tun.ko. I just install it after bootup and never power down the box. Personally I don't mind this but that is up to you.
What you can do is install SManager which can run scipts afer boot up. It can then copy the tun.ko to the correct folder. Tried it and works fine.
Regards.
There are currently 2221 users online. 2 members and 2219 guests.
