Kit Kat 4.4.2 RK3066 (Fully Working)
Originally posted by joaoluizt View Post
Originally posted by joaoluizt View PostMe too, but i think nobody is reading this topic anymore. I need the Flashable OC Kernel.
CS918II/16GB(HTC-031-V1.0 board)
CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
Re: Kit Kat 4.4.2 RK3066 (Fully Working)
Originally posted by sam tyler View Postsorry for not replying, for problems with stock kernel check one of my posts a page or so back basically you may have under clock it.and I don't have the overclocked kernel. I also have the mk809ii and once I under clocked the ROM it stopped rebooting and getting hot.hope this helps.
Hopefully the kernel digger kindly provided will help you out too. Good luck
Originally posted by eric_zapata View PostCannot root this rom with Kingoroot, another method?
MX2
windows 8.1
Installed all Rockchip drivers, no luck.
Thank you guys.
Originally posted by digger View PostI hope this one you're looking for
https://mega.co.nz/#!E9xiySpI!oU2s7h...BdvFlzd55-02mI
CWM flashable kernel zips
Devices all have different OC tolerances,so here's some flashable OC kernels for users requesting them. If you prefer to flash with rk batch tool simply extract the kernels. Otherwise flash zip via CWM.
Good luck!
[1608][400][533] zip http://ge.tt/4W8vYu62
[1512][400][600] zip http://ge.tt/1OsXXu62
[1608][400][600] zip http://ge.tt/9OCMWu62
Originally posted by himmon View PostCheers mate, thanks a lot
I'm using a adapter from a Iphone but the OC from Kernel only works only until 1.416 (stable) because its just 5.1v/2.1A.
Originally posted by Kozon View PostHello toperez!
The password is not good, as I wrote earlier posts. can you help?
*** = www
***.hindotech.com
This has been mentioned many times within this post.
Password is the following in lowercase: w w w . h i n d o t e c h . c o m
Obviously minus the spaces within the password. Easier to just type the password rather than copy/paste if you're still having problems.
BT problems
I bought an mk808b with already install 4.4.2. Everything work wifi is excellent.But i have a problem with the bluetooth. Although it works and it search the other bluetooth devices (like keyboard) and also connected the connected keyboard or mouse don't react with the tv box. Do you have any idea;
Peripheral Issues
OK, so I figured out/found workarounds for most of the issues I had with this ROM, but one REALLY annoying one remains.
The stick crashes from time to time (usually when left on overnight) - which is something I could live with, but the big problem is that I have to unplug EVERYTHING attached to it and wait until I get to the Android home screen before I can plug in peripherals (USB mouse & ethernet adapter). If I just pull power and put it back in with the other USB peripherals plugged in, the ROM gets stuck on the dancing circles boot screen and never makes it to the android home screen.
I've tried using other power adapters from the HP Tocuhpad (2.1A), the OnePlus One (2A) and even bought a 3A adapter, but all have the same problem. Also, I don't think heat is the issue as I can't get to the android home screen if everything is plugged in from a device that has been unplugged for an hour, so I don't see how the cpu could overheat just booting from a cold start - and the box doesn't really freeze, it just get stuck on the boot screen.
Would love to be able to fix this issue as it's a real PITA to have to get behind my receivers to unplug all the cables, wait for android desktop and plug everything back in a couple of times a day.
Edit: This is with stock kernel with NO overclocking whatsoever.Cozyswan MK809II - 4.4.2
Vega S89 Elite - 4.4.4
There are currently 3012 users online. 0 members and 3012 guests.
