Tronsmart S89/S89H & Beelink S82/S82H/M8 - Finless 1.8 ROM
Originally posted by Prodb View PostHi Finless,
is there a chance for an 1.9 Finless rom with 107k4 next time?
Gesendet von meinem GT-I9505 mit TapatalkMk802IV Neomode 1.9a original rom 720p
I do feel slightly embarrassed to ask this question but after searching for nearly 30 minutes I just have to: I'm trying to install the Finless ROM so I can finally use the S82 as a SNES/N64 with my Xbox controller but I just can't find the reset button. Please help me and don't make me feel like the worlds worst engineer.
Originally posted by In5anity View PostI do feel slightly embarrassed to ask this question but after searching for nearly 30 minutes I just have to: I'm trying to install the Finless ROM so I can finally use the S82 as a SNES/N64 with my Xbox controller but I just can't find the reset button. Please help me and don't make me feel like the worlds worst engineer.Please consider making a Donation to freakTab
Originally posted by blinkone View PostIts hidden in the AV hole,Use a wooden toothpick or a non metallic item to to press the button
>edit<
ROM works great, XBMC works great, Super Mario with Xbox controller works great. You are awesome, Finless.Last edited by In5anity; 21 July 2014, 20:05.
Originally posted by In5anity View PostWow, never would have thought of this. Thank you.
>edit<
Rather a creative place to put itMk802IV Neomode 1.9a original rom 720p
hello everyone. i would like to know if there is a way to make my exernal sdcard as default by the system and not internal storage. i own a tablet that i got from geekbuying where it gaveme options to select which one to use as default and worked well.
another thing is i have a 3tb hdd pluged in my vega elite for xbmc but in the browse for share >>external storage it take me to internal storage, so it would be better in my opinion to go to real external storage like sdcard and i need my external hdd to display as an option too INSTEAD OFy go to root >> storage>> etc every time i want to add a source... how can i do that?
not sure if this the last is firmware related or xbmc related. thanks in advance
Need root for reboot...
Hi everyone !
First thx bob for your great roms.
I wanted to use the reboot function, but every time i'm having a pop up message saying that i'm not root does anyone experienced this as well ?
I'm using finless 1.8 rom on a MBox S82 16g (ordered a tronsmart S89H and ended up with that thx to dealextreme...), and for sure it's properly rooted as said by Bob himself and other applications using root function works perfectly.
I tried to mess with super su who confirm i'm rooted, allowed root at boot or for reboot function with no luck.
Since it's one of the main functionality compare to stock rom and as Finless roms are rooted is there anything to do to make it work properly ?
EDIT : solved, found out that in fact reboot is setting by default in refused for root access in super su, had to allow root AND save (what i didn't do the first time). How dumb of me...
Originally posted by Veronica View Posthello everyone.
1.) i would like to know if there is a way to make my exernal sdcard as default by the system and not internal storage. i own a tablet that i got from geekbuying where it gaveme options to select which one to use as default and worked well.
2.) another thing is i have a 3tb hdd pluged in my vega elite for xbmc but in the browse for share >>external storage it take me to internal storage, so it would be better in my opinion to go to real external storage like sdcard and i need my external hdd to display as an option too INSTEAD OFy go to root >> storage>> etc every time i want to add a source... how can i do that?
2.) I only can talk about minix, but there I see my external HDD as sda1 at xbmc, but if I remember correctly there is maybe a problem with HDD > 2TB at the moment...RK3288 Devices
- Overview BOX (LINK !)
Anybody else have problems with this Rom being very slow?
I have 2 S82 boxes, 1 runs mint, the other runs terrible, xbmc crashes and freezes all the time, kicks video out, had similar issues with the original firmware that came with the box, can't remember what it was, possibly 102k4, other apps run super slow too, even the home screen animations are brutal slow
What's weird is I put 1.7 back in and it runs fine, never had an issue with 1.6 either
corrupt download maybe? I'm sure I used the exact same TF card to flash my other box though
Originally posted by Steve604 View PostAnybody else have problems with this Rom being very slow?
I dont think its the box but a bad bit of code coming from the stock firmware which this rom is based on.
Stane1983 seems to have removed the animation issues from his rom.
His of course is based on older firmware so its got the standby bug.Last edited by Magnus33; 23 July 2014, 21:48.Mk802IV Neomode 1.9a original rom 720p
I'm having video crash issues with his firmware too,
I was having a blurred video problem with oman xbmc, and could only run the stock skin
That's why I went 1.8, My other box runs standard 13.1 xbmc no problem on the 1.8 rom,
went to Stanes XBMC with 1.7 on this box, seems ok so far
Could be missing something, I'll have to try again on of these days, problem is that box is in my living room, and I watch 90% of TV through it, wife's not to happy when I take it, wipe it and start changing things
There are currently 1798 users online. 0 members and 1798 guests.
