Tronsmart S89/S89H & Beelink S82/S82H/M8 - Finless 1.8 ROM
Originally posted by Biatsch View PostI edited Audio_policy.conf file in etc so no usb Audio will be used check it out https://www.dropbox.com/s/u3npz5domu...io_policy.conf Audio wont be send anymore to F10Pro and to other usb audiodevices
dont Forget to set filepermissions after Insertion and reboot
(Mele F10Pro mic. works wel as input device. )
Output:
# usb_accessory {
# sampling_rates 44100
# channel_masks AUDIO_CHANNEL_OUT_STEREO
# formats AUDIO_FORMAT_PCM_16_BIT
# devices AUDIO_DEVICE_OUT_USB_ACCESSORY
# usb_device {
# devices AUDIO_DEVICE_OUT_USB_DEVICE
I think the problem is audio output sampling rates (slow motion sound when different samling rates). Mele working on 48000. On this conf file 441000. Maybe need to change the settings of others (Alsa, drivers, etc..)
Works GREAT Bob!
Thanks a lot Bob for a wonderful job.
I was having problems with the official roms and Omans XBMC 13.1 and 14 versions.
Whenever I would stream a HD movie from the Internet it would look like it was badly interlaced and jagged.
Using your rom I can use the official XBMC 13.1 and now all is good :-).
Once again bulk 10x!!
Looking forward to your next release
AW: NEW - Tronsmart S89/S89H & Beelink S82/S82H/M8 - Finless 1.8 ROM
Originally posted by hdsl View Post
Disable only output device. Does not disable input section
Output:
# usb_accessory {
# usb_device {
Hi,i have a standard Tronsmart Vega S89 with 16GB on witch i installed 1.8 ROM yesterday and also the Last version of Oman XBMC and i still have the same problem i had before i did all of this..playing 1080P (HD) movies,after exactly 10 minutes video stop and audio is going on...i don't know what to do ..some of guys here are saying its working fine..am i missing something?? i played the movie using different hardware acceleration setup and played different movies from Mashup/Demon88 ...the same problem over and over again.
I am ready to make a donation if somebody can help me fix this..i am rely pissed off about this,on my laptop the XBMC works like a champ,know i regret i bought this box
Thank you for the work you did guys..
Re: NEW - Tronsmart S89/S89H & Beelink S82/S82H/M8 - Finless 1.8 ROM
Originally posted by ozy81 View PostHi,i have a standard Tronsmart Vega S89 with 16GB on witch i installed 1.8 ROM yesterday and also the Last version of Oman XBMC and i still have the same problem i had before i did all of this..playing 1080P (HD) movies,after exactly 10 minutes video stop and audio is going on...i don't know what to do ..some of guys here are saying its working fine..am i missing something?? i played the movie using different hardware acceleration setup and played different movies from Mashup/Demon88 ...the same problem over and over again.
Originally posted by Fragmaster View PostIf you are getting the same problem with all the rooms it could be a hardware issue, I recommend you to return the box in that case
I bought this box just to use xbmc and maybe play some games if its working.
I tried Tanktastic and it didnt work.
to ozy81
just my thoughts on your issue...
What do you play the movies from?
Thumb drive or usb powered hard drive or maybe a network drive or...?
i had the same issue with a "sandisk cruzer blade 16Gb" on both my wdtv live media players and even my pc... movie playback also halted after a set amount of time...
(it was due to the the usb stick being to slow)
so my thought:
maybe try another "faster" usb device and also try putting it in the other usb port...
another thought:
when you boot the tronsmart, wait for at least 10 minutes before starting xbmc so android can fully boot (just to be safe, maybe this can also be of some help, it helped me with my JXD-S7800B... this one also boots really slow with the custom rom i use)
hope it helps
no problems at all untill now
i also watched some movies on navi-x no problems .1080 mkv series on a phillps usb3 stick no problems .Netflix with hola (watch netflix on other region )no problem only takes a little longer to start a movie ore serie.all stable no hangups no sound problems .
where with the stock 105k4 i had some problems with xbmc stopping needed to restart untill now i havent descovered any problem .
i have used methode 1 to install the finless 1.8 .and i have only mx player xbmc hola and netfilx and tuneln pandora installed on my tronsmart s89-h
Originally posted by wheelboy View Posti have used the 105k4 with no rooting ore whatever .i did have some slight hickups when playing a movie on a stick with xbmc that was the 14 version .yesterday i have installed the finless 1.8 with the oman xbmc .did almost no ajustments only sound 5.1 and hdmi passtrough .looked movies the whole evenig no problems anymore .
no probems untill now
I Played yesterday with xbmc .
bd .iso 1080p with dts-hd ,No problems ,also dts sound
1080.mkv several . No problems
720 mkv .no problems
divixhd .no problems
divix .no problems
All from a usb3 stiick
then i played some movies from navi-x .There i had a buffer problem with one 1080p movie .i have solved that by using xfinity .played the same movie no problems anymore .
what i havent tried is streaming from my laptop to my s89-h and from our nas server but to be honist i heardly use both since putting it on a stick goes faster than on my nas .
i havent encounterd any problems untill now .i use the finless 1.8 and oman xbmc .
See what it does with a usb stick if u have one as i understand it u use the internal memory? havent tried that .But in my opinion internel memory shouldnt be any problem .i will try it out today and let you know my findings with the 1080p
First thing thank you Bobfor another great rom just flashed it to my measy b4a haven't got the time yet to test it further i am sure that everything will work fine one thing that i found out is when i select the 1080p 24hz resolution the screen gets windowed in a small square in the upper left corner other than that everything works well
Originally posted by aeolous View PostFirst thing thank you Bobfor another great rom just flashed it to my measy b4a haven't got the time yet to test it further i am sure that everything will work fine one thing that i found out is when i select the 1080p 24hz resolution the screen gets windowed in a small square in the upper left corner other than that everything works well
There are currently 2434 users online. 1 members and 2433 guests.
