PCB Version/revisions cs918 and T-r42
    Originally posted by TRoN1 View Post
    Same board as above. I have the same problem, hit power button and red leds come on for 5 seconds, then off. No tv output and the leds never turn blue. I searched EVERYWHERE for a solution but found nothing. And NO, it's not the power supply, tried several. Anyone?
    TRoN
    my board has SK hynix H27UCG8T2ETR NAND flash, which goes in mask mode by shorting 29 and 30 legs.
    but problem is , after masking or direct USB flashing, my laptop is not recogenising , not asking for driver also.
    so my search is for driver for now.
    if you have same board, and found something, please PM me.
      anyone recongnize this PCB ? from flush tool:
      Reading flash information
      Loading partition information
      MACHINE_MODEL:rk312x MACHINE_ID:007 MANUFACTURER:RK30SDK MAGIC: 0x5041524B ATAG: 0x60000800 MACHINE: 312x CHECK_MASK: 0x80 KERNEL_IMG: 0x60408000 #RECOVER_KEY: 1,1,0,20,0 CMDLINE:console=ttyFIQ0 androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0 x00002000@0x00004000(misc),0x00000800@0x00006000(b aseparamer),0x00007800@0x00006800(resource),0x0000 6000@0x0000E000(kernel),0x00006000@0x00014000(boot ),0x00010000@0x0001A000(recovery),0x00020000@0x000 2A000(backup),0x00040000@0x0004A000(cache),0x001FE 000@0x0008A000(userdata),0x00002000@0x00288000(met adata),0x00002000@0x0028A000(kpanic),0x00180000@0x 0028C000(system),-@0x0040C000(user)
        дайте нормальную прошивку cs 918 q 7 x6 v 21 / спасибо
          HI, I recently bought a CS918 RK3188T (no I don't know why either) lol.
          Anyhow I find it slow and wanted to change the Rom if possible but can't Identify the device model.
          *Board has CS918_V30 2015_07_23 on it. Which firmware can I use as my wifi doesn't work due to a wrong firmware being applied.
            Originally posted by cocopera2k View Post
            I received this device a few days ago and need to return an error to introduce the firmware ...
            That is why we need the firmware.
            http://www.****.es/itm/CS918-Android...item20fb104eb3
            RK3188T Quad-core Cortex A9 de 1,4 GHz
            The board is a rk918_v1.20 141008
            sku: v580eu16g
            I have a same devica. When i want to flash , i get IDB error. I dont know how to fix this. Device dont get any sinal on tv , only black screan. It onli worked one day, and after that problems. Please help me to fix this,
              Here my new Device for playing around a little bit...
              ...maybe you can work with the Pictures ... ?
              Have Fun !
              ... TVDroid
              > > > Devices: Minix Neo X7 & HiSilikon® T-R42 II < < <
                  Originally posted by Piuizando View Post
                  Q7 CS918 2g 8g board X6_V21 2014_09_20
                  Android yanghui_test 20150602
                  ​Link Original China : http://pan.baidu.com/s/1pJn5WJh
                  Re Upload Mega: https://mega.co.nz/#!z9ZgVbSR!RP9rDQ...sLloTu3A0fWlCM
                  PLEASE! Can You reupload the firmware? those links apear to be down. Thanks!
                    2015-10-26 - Stock ROM for Q7
                    Build number:
                    rk3188-eng 4.4.2 KOT49H eng.yangfeihu.20151026.104657 test-keys
                    Kernel version: 3.0.36+ Mon Oct 26 10:45:44 CST 2015
                    Archive name: update_Q7_ZhongXing_20151026.zip
                    Size: 514mb ZIP / 469mb RAR
                    Link 1 (514mb ZIP) Link 2 (469mb RAR)
                    Link 3 (514mb ZIP Russian link)
                    I've tested it very thoroughly on XT-Q7V-V10 2014-08-15 and works like a charm, very nice stock firmware!
                    Found it in this 4pda.ru thread: http://4pda.ru/forum/index.php?showtopic=490384
                    "The thing with me is that I AM smart and I'm self smarted, basically from nature and smoking drugs and doing different things I've self learned myself. And that's the whole difference I guess is that I don't need the books or the schooling type things. People say books and college are for-to-be to make you smarter, but they can also be for-to-be to make you dead. My brain only uses half the oxygen because it's only part full and that's why I'm alive right now." -- Ricky from Trailer Park Boys
                      I am having problem with my Q7 (XT-Q7-V10) yesterday. It has automatically uninstalled some apps and the icons are now greyed. Clicking on it give a message that the app is not installed. I have tried installing the apps again but it will not install with the message "Installation Failed". I have cleared all the cache and any remnant from the uninstalled apps, turning the "Unknown Sources" on and off various times, but still fail to install any app. It also failed to restore from Titanium Backup
                      I have also tried to do a factory reset but it will not factory reset as well. I also noticed that I can't turn on wifi. The slider will not toggle. However I can still stream music, play Youtube with the unit wire connected to the modem. But I cant install any app from Google Play Store. The app will download but it will not install.
                      I guess re-flashing the firmware is the last solution. But before that does anyone has a solution.
                      Next is there a step by step tutorial on re-flasing the firmware.
                        cs918-2+8-15.0.2015-06-15.zip
                        https://mega.nz/#!CopjDS5S!WeCi3Outt...b-OLawLYh1St44
                        https://www.dropbox.com/s/5lyt9w0kj1...06-15.zip?dl=0
                        https://drive.google.com/file/d/0B3-...ew?usp=sharing
                        https://onedrive.live.com/redir?resi...int=file%2czip
                        ​cs918-2+8-15.0.2015-06-29.zip
                        https://mega.nz/#!7wpHHIQb!1bk-ujrk-...ZHqP9H2KGjM0aI
                        https://www.dropbox.com/s/6gwje4pkry...06-29.zip?dl=0
                        https://drive.google.com/open?id=0B3...VRXZllERF9PQWc
                          Thanks!!! i have 2 of these ..suposed to be 2gb ram.... they have a sticker inside that says 2G/8G...but using a hardware analysis app...both report 1GB of ram...
                          Does your unit report 1GB or 2 GB?
                          Thanks again!
                            Can't get any firmware for the red board HLSX_X6_V10. Anyone have it? 4.2 or 4.4 prefered!
                              Anyone had luck with windows 10 usb drivers for rockchip..cant get to install the drivers and flash a new firmware for it..using rkbatchtool..any links for how to do it right?thanks.
                              Sent from my SM-N910F using Tapatalk
                                Could you help me to locate this firmware? Thnks
