PCB Version/revisions cs918 and T-r42
    Re: PCB Version/revisions cs918 and T-r42
    Can anybody confirm for my box..if any of wassers firmware works with this pcb...K-R3188 V4.3..nobody seems to be confirming that it works...its like im lost in the dark...or they may have same box as mine.. And what custom roms are they using thanks.....pics..attached...thanks in advance...
      I think it is the K-RK3188-V4.3 without BT and at the moment I don't know anyone who have find a custom rom which work at this version...
      RK3288 Devices
      - Overview BOX (LINK !)
        Yes it is..the one without bluetooth....so no custom rom for it...bad news for me...then.....
          There is really no chance for my pcb board of having a custom firmware...very sad..anybody here have the same as mine..thanks... K-RK3188 V4.3 BOARD..NO BT..
            Hi guys, i just got one of these devices, and the board is HLSX_X6_V12 the same one pictured in post number 2 sixth one down. However, it seems there is not stock or custom rom available for this device. I tried patching the kernel which is actually in the boot image of the rom for this device to fix the stuttering issue, however, the patch doesn't seem to work with this particular kernel. I still get stuttering after patching the kernel using the rkpatchomatic-master tool. Is there any other way to patch the kernel if this tool won't work? I'm just interested in smooth xbmc playback, and this particular device with this board revision sucks at that and on the whole the device seems really laggy, maybe could be due to the fact it's using a RK3188T cpu. Whenever I try to used my usb keyboard mouse, it goes all haywire, pressing a single button sets of this never ending clicking, it keeps clicking over and over until i pull out the usb nano receiver for the keyboard/mouse.
            Here's a couple of photos I took of the product.
              For those with a Q7 device, eve_Snuffy has put together an excellent resource for stock and custom ROMs:
              Thanks eve_Snuffy!
              Speaking of great resources, thanks for making this thread mitchell4you. It helped me and I'm sure countless others. It should be a sticky.
              "The thing with me is that I AM smart and I'm self smarted, basically from nature and smoking drugs and doing different things I've self learned myself. And that's the whole difference I guess is that I don't need the books or the schooling type things. People say books and college are for-to-be to make you smarter, but they can also be for-to-be to make you dead. My brain only uses half the oxygen because it's only part full and that's why I'm alive right now." -- Ricky from Trailer Park Boys
                Just got Q7 the other day, the stock rom is Kitkat. LAN an BT work. Not sure from this info, can we tell which PCboard version it is, without uncovering it?
                  is there a video or guide on how to open the boxes?
                    There are 4 screws under the rubber feet which you can remove...
                    After that, it's really easy to open the case....
                    RK3288 Devices
                      thanks
                        Here is mine
                        BTW, I had a black sticky pad on the Rockchip, instead of a heatsink, like some in the first post.
                        I just pulled it out.
                        Does anybody have an idea what is the reason for sticking that pad on top of the processor?
                        To keep it warm?
                          Is there any rom for this version : K-RK3188-V4.3 without bluetooth ?
                            XT - Q7S - V02 I think it is a Q7 with Camera and Mic (for skype)
                            I bought it from ****, I'm struggling to get it rooted (I use TPSparkeyRoot) after installing the moborobo and getting the USB to seemingly work, TPSparkeyRoot goes through no problems no errors but when I run Root Check it gives me a Big fat NO!! Any advice would be appreciated.
                            Here is an image of the PCB, Ribbon connector for the 2mp Camera is above and to the right of the Heatsink
                              Here is another one you may add to OP:
                              XT-Q7V-V10 2014-08-15
                              when asked ETY for new firmware, I got the following email:
                              here is the firmware:
                              http://pan.baidu.com/s/1o6HPUUA
                              when you download the file from it, pls click the upper right box writing 349.7M, and then the right box.
                              here is the tool:
                              http://yun.baidu.com/share/link?uk=3995530201&shareid=843456240
                              when you download the file from it, pls click the upper right box writing 1.05M, and then the green box.
                              here is the guide:
                              http://yun.baidu.com/share/link?uk=3995530201&shareid=977820737
                              in the guide, we take mk908 as an example, which is same as mk908, just the recover button of cs918 is on the bottom of the box.
                                need some help...
ID:	435413Click image for larger version
ID:	435414Click image for larger version
                                any idea about this one.... I am still wondering about the name of this stick...
                                Using this one for long time but still no idea what I amusing...
