Thanks for him!
PCB Version/revisions cs918 and T-r42
I have this CS918 v7, I was able to make a backup of the stock firmware by following the tutorial by "Bob". Does anyone know if there is any firmware that supports DTS/Dolby that can be flashed on this board?
The specs are:
MOTHERBOARD: CS918 V7.0 20141208
CPU: Rockchip RK3188T
RAM: 1GB
NAND: SK Hynix H27UCG8T2BTR (8GB)
Audio: Rockchip RK1000-S
Wifi Bluetooth: Realtek RTL8723BU
Rockchip RK616 Ethernet: IC Plus IP101GR
regardsLast edited by ganjaman2009; 09 April 2015, 00:10.
The specs are:
RAM: 1GB
regards
The strange thing is that when I first got the CS918, it was only able to output video as 720p. I went into Settings and did a factory reset, apparently the "backup" kernel was 1080p and the installed one was 720p. I installed SPMC via Play but that audio output was garbled in all modes but it showed the video as 1080p - "default", SPDIF passthrough" and "HDMI". I installed Kodi, but there its only stereo in any mode and it shows the video in 720p. Very strange indeed. I have a Boxee that runs Kodi off NFS, only problem is that it cannot output DTSMA, is it possible to have the CS918 boot of f SDHC or use the SDHC with a cross compiled kernel for ARM? I am willing to figure out how to cross compile Android with the proper options, and to properly flash the NAND. I don't have many leads but Google has provided me with a start. Anyone who does know - I'd be grateful for any pointers. When I do have the results I need - I will post the HOWTO or the pertinent links.
Originally posted by obufk View Posttry this firmware
CS918 android 4.4 firmware : http://pan.baidu.com/s/1sj0o77n
[30.03.2015 6:11:06] cozyswan--linda: CS918 ANDROID 4.4 root firmware,
http://pan.baidu.com/s/1bnxZO8v password :buqu
did you try this ROM?
also I can't download the [30.03.2015 6:11:06] cozyswan--linda.... there are many links there all in Chinese
Hi to everyone, "maybe" i found a compatible image for the pcb "HLSX-CS918 v1.1". I found the image from this link: http://pan.baidu.com/s/1hqopWSs
wifi, bluetooth and ethernet works, but after every shut down it's needed to disconnect and reconnect the power plug to restart it ( sorry for my bad english )
The remote controller don't work, and there are 2 launchers. The streaming video are very bad, probably due to the 1388T, for me it's the worst pcb for this deviceLast edited by topo70; 27 April 2015, 22:54.
These android boxes are simply good if you wanted to connect it to a TV and your internet. Its not for those who want a media player HTPC. It is too easy to buy the wrong one and expect DTSMA or Dolby output. My WDTV did all audio formats, and I was wrong to assume that these cheap no-name boxes could do that. I would not even consider Beelink or Tronsmart anymore. Instead, I got a ZOTAC CI320-NANO with 4GB RAM (CAD$230) and a 16GB USB3 flash drive ($7.99). I installed OpenELEC-Generic.x86_64-5.95.1 beta, and everything just worked. The only exception was CEC which Zotac does not support. Intel NUC does support CEC. The time now correct, KODI was always 1 hr behind, my timezone is also now selectable and NTP servers are fully configurable. I get DTSMA via passthrough which really rocks. I decided to give my CS918 away to someone who was okay with stereo. The great thing is that I can easily reinstall OpenELEC or Windows or Kodibuntu and not worry about bricking. I might put in a 120GB SSD if the prices drop around $40, right now they are $60. Its too bad theres no OpenELEC for ARM, imagine if it could be written to a USB or SDHC card, only thing is that some folks use their Android box for more than just Kodi.
I received this device a few days ago and need to return an error to introduce the firmware ...
That is why we need the firmware.
http://www.****.es/itm/CS918-Android...item20fb104eb3
RK3188T Quad-core Cortex A9 de 1,4 GHz
The board is a rk918_v1.20 141008
sku: v580eu16gYou may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoLast edited by cocopera2k; 26 May 2015, 20:18.
I found another alternative - and its costs about USD$100 - WeTek.com, "Play Android" - its the same price as the Beelink or Tronsmart except it can boot OpenELEC. Its comes in three configs: plain Kodi (Android w/Google certification) TV box, DVB & Kodi or ATSC & Kodi. It also allows you to install OpenELEC. The base features include DTS & Dolby passthrough. In terms of obsolescence, once they stop releasing new firmware, you have an upper hand over the others (Bee, Tron etc) - you can install the latest version of Kodi. I looked at it and it has a dual core AML-8726 with 1GB of RAM & 4G NAND. Wetek uses their own OS, but they allow you to boot off the SDHC to run a fully supported version of OpenELEC. I know folks will say "I can get a quad core with 16GB NAND & 2GB RAM for just $20 more" but I'm exploring all my options with preference over obsolescence protection.
hi id like to add my device with its stock rom.
4.4.2 (not rooted but easy to root with kingo root)
any custom rom for this?
4.4.2 stock
Originally posted by thadeustr View Posthi id like to add my device with its stock rom.
4.4.2 stock
i think that is the new pcb, cs918 v7.0 and there is no custom rom for it yet.
Q7 CS918 2g 8g board X6_V21 2014_09_20
cs918-2+8-15.0.2015-06-15.zip
https://drive.google.com/file/d/0B8s...ew?usp=sharing
https://mega.nz/#!TtZnRSDQ!UEYzxuqLZ...VUXPIVMPKJFkCI
There are currently 3777 users online. 0 members and 3777 guests.
