PCB Version/revisions cs918 and T-r42
    hello, thank you very much for your advice .I sent an email to the seller and we are negotiating to send me another .regards
    [Quote = FriskyDingo; 273038] Hola mugre27 él USADO El Traductor de PODRIA Que Lo Por Esto Escribir google párrafo no SER Las mejores cajas spanish.Those hijo basura! E El firmware trabajará Pero No lo puedo Solucionar Problemas SUS, USTED Tendra Que Ponerse en contacto con el vendedor y Obtener ONU reembolso Condiciones o exchange.Also si se toma el PCB y mira al final de Que Verás Poner ONU disipador de calor y alli Creo Que esta causando ONU corto circuit.I Eliminado el disipador de calor de la mía, Pero AÚN Mismos problem.I Piensan Tal Vez si se quita el disipador de calor los antes de encenderlo Por Primera Vez Que Podria Estar Bien. Also Hizo suyo Vienen En Este cuadro? Por cualquier otra persona si recibe uno de estos cuadros de abrirlo y quitar el disipador de calor de la parte inferior de la PCB antes del primer ponerlo en marcha y nos deja saber si funciona correctly.Also este es el cuadro de mi mala entró. [/ quote ]
      Glad I could help, I wasnt sure if google would translate what I said into anything that even made sense.It seems your english is good too though, the seller I bought from first offered a 30% refund which was an insult.I demanded a replacement and it should be here next week.If I end up getting the same box I will open it up and remove the heatsink from the bottom and report back if that fixes it.
        I need a custom rom. I have the real rom only there is a bug. Please help 😣
          XT-Q7V-V10
          No custom roms available but maybe http://www.freaktab.com/showthread.p...l=1#post263587 ????
          RK3288 Devices
          - Overview BOX (LINK !)
            What does your pcb look like and whats the 'bug'? If the bug is random reboots then you have a faulty box.I have just received my second faulty box out of 16 I have bought so far.The seller I deal with now is pretty nice and gives me a 5% discount and splits the return shipping with me.If they didn't give me the discount I would raise hell like I did with another seller to send me a box without returning the bad one but I like the business relationship we are developing and their product is good and arrives in a decent amount of time.
              Originally posted by FriskyDingo View Post
              What does your pcb look like ...
              look at my answer one post befor and at http://www.freaktab.com/showthread.p...l=1#post260077
              RK3288 Devices
                I must have been distracted when I posted, not sure how I missed that.
                  Hi the problem os that the sound sync with the image. With kodi i can speed up the sound with 200mini sec. Only with netflix it cant
                    What resolution are you running at? Sounds like its set to 1080p
                      Can someone tell me what is this device & what ROM can I use for this. I have purchased this device from DealsPrime as " Tronsmart MK908 Quad Core Android 4.1 Mini PC - 8GB RK3188 1.8GHz HDMI Wifi TV Stick Dongle" in late 2013.
                      I have used followings so far but they don't seem to work.
                      1. Mk802iv Old WiFi. New oficial firmware kitkat 4.4
                      2. MK809III - KitKat 4.4 - SMIC717394 ---- 1080p ROM
                      3. MK908T428 Hybrid Firmware (HFW) 1.1.2 by lewy20041
                      4. Tronsmart MK908 Finless 1.7a
                      Following from Baidu works, but are not very stable.
                      1. MK908_publice HTC_AP6210_20131209
                      2. T012_publice_AP6210_20131209
                      Can someone please let me know the stable ROM from freaktab that I can use for this device.
                        Originally posted by Allen View Post
                        Model: gxt_stb_3188
                        Manufacture: Rockchip
                        Chipset: RK30Board
                        RIL Version: KitKat ril-rk29-dataonly v3.3.00
                        Build Number: gxt_stb_3188-eng 4.4.2 KOT49H eng.ren.20141121.094523 test-keys
                        CPU Clock Speed: 504 MHz - 1416 MHz
                        Kernel Version: 3.0.36+
                        Graphics: Mali-400MP
                        Got it few days ago from Amazon (Seller: 99 Digitals)
                        It says "GXT_RK918_V1.10 141008" on the motherboard. Looks similar to V1.0 posted above. It has RTL8723AS wifi/bluetooth adapter soldered onto the board. This box came without rooted but I did it with Rockchip driver and TPSparkyRoot tool.
                        and here yet another reivision, only different thing is the WIFI_BT module, that's RT8723BV.
                        I just got the tv box, aside from the lack of a heatspreader (i'll go check in my old box if I can adapt something to fix it) which may be the cause for reboot, freeze and sometimes video glitches... the ROM is kinda buggy, so any chance anyone out here has the same board as myself and can help me find a newer firmware?
                          Can any one help with this one
                          Got this but cant find stock rom anywhere.. any one else got this ?
                            XT-Q7-V11 2014-07-14
                            stock rom seems to be here http://www.freaktab.com/showthread.p...V11-2014-07-14 but custom rom looks bad
                            also google doesn't really helps
                            RK3288 Devices
                              New CS918 model?
                              Hi
                              I need the stock ROM, i know how save the original for the tvbos and custom ROM,
                              My main problema is that when shutdow by menú, it is not posible startup, only unplug de power cord.
                              I have instaled de superus and App for power off and obtain the same result. checked the power supplied and this is ok. I think the kernel in not correct.
                              help for this issue.
                              [IMG][/IMG][IMG][/IMG][IMG][/IMG]
                                newer clone out there cs918 ver 7_0
                                have seen posts on here regards to new clone.. have obtained an image with better performance from manufacturer .. cs918 clone ver 7.0
                                here is the updated firmware with root and cloning tools - use rk batch tool hit button on bottom left and can change it to english language from chinese when it opens.. select the image file from recover option after holding reset button while plugging unit in to a power source to get in proper mode to flash
                                board is identified as a cs918 ver 7_0 production date stamped of 20141208
                                this file has been provided direct from manaufactuer.. smooth 1080 playback and great on live streams
                                Last edited by kevingamble; 07 March 2015, 16:16. Reason: correction about root - not rooted image
