Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 4 July 2014
    Here's a lightly reworked ROM based on Cube's U65GT V1.8 firmware of 04 July 2014.
    I've posted a reworked frimware based on cubes 1.8 firmware of 6 Aug 2014 at
    http://www.freaktab.com/showthread.p...-2014&p=218865
    ROM Download
    So what do you get?
    • UK English by default
    • Root
    • Removal of Chinese apps
    • init.d support with busybox integration
    • option of CWM recovery built with rua1's MTK Droid Root Tool, also included is Lepi's TWRP recoveries
    • auto install feature:- if you create an autoinstall folder on your sdcard containing any default apks they will install on first boot. I tend to be sparing in this just loading my preferred file browser, terminal emulator and titanium backup.
    I've included instructions within the download for flashing both the full ROM (required if you are changing from Cube's earlier firmware) or flashing just boot and system (ANDROID).
    Hope this is of some use.
    Brian
    PS Lepi pointed out to me that its easy to boot into recovery as follows. First power off the U65GT, it vibrates when shut down completes. Press and hold power for about a second then press and hold vol+ until a menu displays (its small in white). Scroll through the menu options with vol+ and select with vol-
    CWM zip fix for read only external sd card. Download and put onto the sdcard (internal or external), reboot to recovery and update.
    extsdcardfix.zip
    CWM zip for 6 Gig apps space
    partition_6gGIG.zip
    Lepi has uploaded an updateda TWRP Recovery links in the following quote
    Last edited by 900supersport; 23 August 2014, 13:30. Reason: update for link to newer firmware
    900Supersport
    freaktab developer
    really nice, will try it tonight! Thanks a lot!
      Thanks a lot !
      It runs fast
        Brian
        In this post Lepi has uploaded a TWRP Recovery
        Brian, thanks for the modified firmware. Downloading.
        I'm sorry I forgot to warn that TWRP been updated from 07/05/2014. It once again eliminated interface errors.
        Посмотреть и скачать с Яндекс Диска
        Thank you.
        videoTutor1 videoTutor2 videoTutor3 videoTutor4 videoTutor5 videoTutor6
        TWRP_2.8.1.0
        TWRP_2810_newTheme TWRP_2.8.5.0
        PayPal donate WMID410517421626
          Downloading...can i help with testing and development of u64gt rom in my spare time? I want to squize every bit of performance out of octa core+gpu.
          Where can ifind changelog for every build. Is there any chinese web site with more resources?
            [QUOTE=Lepi;201142]Brian, thanks for the modified firmware. Downloading.
            Thank you.[/QUOTE
            How hard is to update to the latest TWRP. From my experience i find the best philz touch modded CM recovery. I have tryes them all and philz recovery never give me any problems never.
              Please use another recovery example, CWM recovery built with rua1's. I did not ask Brian include my TWRP in firmware.
              I asked users to write errors that are seen. No one has ever written. Ask specifically describe what you did not like in the recovery. I'll be treated if my product is sick.
              My recovery on my tablet is working properly.
              Sorry.
              TWRP_2.8.1.0
                Sorry Lepi
                I should have checked with you first. I'd put your recoveries in my ROM folder and tested. Forgot to pull them before zipping and uploading. I couldn't face waiting another hour or two to re upload so left them in.
                900Supersport
                freaktab developer
                  Sorry Lepi
                  Maybe they should not be imposed my recovery to the users? They can download TWRP separately. Until now, no one has written about possible errors.
                  Solve itself, I just advise. Thank you.
                  TWRP_2.8.1.0
                    Yes in future I'll just add links to the first post on each firmware.
                    Thanks for your support with twrp
                    900Supersport
                    freaktab developer
                      Brian. Explain what Gig apps space. I do not understand as divided memory partitions?
                      Maybe directly in the firmware download EBR2_6GIG and EBR1_6GIG noted in the check-boxes FlashTool. What benefit of this memory markup?
                      sorry.
                      TWRP_2.8.1.0
                        Internal storage on the settings, storage option. Default is 2GB, I normally find I quickly get users that fill this space, so reallocated 4 GB from the internal sdcard.
                        900Supersport
                        freaktab developer
                          Maybe directly in first firmware download EBR2_6GIG and EBR1_6GIG tick in the check-boxes FlashTool?
                          and another question: platform.hml from extsdcardfix the patch is already included in your mod?
                          TWRP_2.8.1.0
                            ROM Download
                            So what do you get?
                            • Root
                            Brian
                            [ATTACH]7000[/ATTACH]
                            [ATTACH]7001[/ATTACH]
                            Brian, I was still having problems with Titianium backup writing to the SDcard even after applying the external sd card fix. I think I have found the problem. I have changed the
                            permission name="android.permission.WRITE_MEDIA_STORAGE"> section to include
                            <group gid="sdcard_all"/>
                            Titanium backup is now successfully writing backups to /storage/sdcard1/TitaniumBackup.
                              Maybe it?
                              Code:
                              <permission name="android.permission.WRITE_MEDIA_STORAGE" >
                                      <group gid="sdcard_all" />
                                      <group gid="sdcard_r" />
                                      <group gid="sdcard_rw" />
                              or
                              Code:
                                      <group gid="media_rw" />
                                  </permission>
                              so it is possible or not?
                              TWRP_2.8.1.0
