Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 4 July 2014
Lepi, I don't have the line with sdcard_all. Just the sdcard_rw and media_rw.
I edited Brian's zip file and repackaged it with the extra line inserted and then installed from cwm recovery as the /etc/permissions directory is ro when the tablet is booted.Last edited by stuarts; 07 July 2014, 16:38.
Originally posted by stuarts View PostLepi, I don't have the line with sdcard_all. Just the sdcard_rw and media_rw.
Originally posted by stuarts View PostLepi, open my zip file and have a look at it.
I wrote these lines, and I began to make Titanium backup on an external SD card. Thank you for the incentive to work.
Code:<permission name="android.permission.WRITE_MEDIA_STORAGE" > <group gid="media_rw" /> <group gid="sdcard_rw" /> <group gid="sdcard_all" />
Installing drivers on Windows 7
I've tried to install the drivers on Windows 7, using the drivers provided.
But without full success.
Whenever I connect the Cube Talk 9X, W looks for drivers and ends up telling me that the device is disconnected.
I'm not sure what to do with the drivers provided with the rom.
I used spinstall, and also dpinst separately on the Infs and on the Unsigned infs.
Can someone describe precisely what I should do to install the drivers?
Thanks in advance,
David
The external sdcard fix from cwm recovery works for me and I can backup to external sdcard.900Supersport
freaktab developer
Originally posted by 8140david View PostI've tried to install the drivers on Windows 7, using the drivers provided.
Thanks in advance,
David
Try setting up your SP Flash Tool first, keep it open, then plug in the tablet while it's powered off. The software should keep the device from disconnecting and the red bar should appear at the bottom of the tool. At that point, you should be able to click download and flash the ROM.
If that does not work, you may need to remove all of your old PreLoader drivers and reinstall the correct one. The older driver included with the Jun 20th ROM worked for me. I followed a few guides online to remove any conflicting drivers. I'll post the links below.
Uninstall old driver entries (run as Admin):
Remove the old INF files:
You need to follow this KB first to view disconnected devices in Device Manager and get the required info: http://support.microsoft.com/kb/315539
Then try this guide to remove the INF files: http://winhlp.com/node/199
Hope this all helps. Good luck!
My TWRP 2.7.0.0
Hi, my friends. Who was unhappy with my TWRP, i offer the patch made by the program Titanium Backup. Inside there are several applications (rebooter, Antutu, SPUMaster, SPUSpy, MobileUnkle Tools, RootExplorer, Wakelock detector etc). Nothing else there. Can be install via my recovery and make sure it works.
If applications do not like, you can delete them later.
File new-update.zip copy on SD card, reboot in my recovery TWRP, choose Install, specify the path to the file and make swipe to confirm. Everything.
This patch is to check work my TWRP.
Happy updating!
Originally posted by pstriolo View PostHello,
Can someone explain me what i have to do in order to upgrade the firmware to the latest version 1.8. I'm a bit lost for the moment.
Thanks for all.
Phil
Nota : ok i find the procedure in the ROM donwload files. Sorry !!!!
Originally posted by Lepi View PostMaybe directly in first firmware download EBR2_6GIG and EBR1_6GIG tick in the check-boxes FlashTool?
and another question: platform.hml from extsdcardfix the patch is already included in your mod?
No platform.xml is not included in the ROM.
I've left these separate as- EBR1 and EBR2 must be flashed as a matched pair
- some people may prefer to keep the stock permissions
Here's a screen grab of storage
900Supersport
freaktab developer
Has anyone tried switching to ART runtime? Seems good to me.900Supersport
freaktab developer
There are currently 2772 users online. 0 members and 2772 guests.
