Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 4 July 2014
Yes but you will need to enable unsigned drivers.900Supersport
freaktab developer
good news!
Because I have an EZCast dongle and to use it with the PC I need to have windows 8.1 (for miracast native function).
And now the same PC will be used to upgrade firmware of the CUBE too.
For info: Pipo tablets are not compatible with windows 8.1, so I was forced to stay with windows 7 or 8 (not 8.1)Last edited by giouncino; 10 July 2014, 20:14.if you appreciate my efforts this is the link for any donation:
I'm using 8.1 so you should be good.900Supersport
freaktab developer
Interesting to hear, compared to the rk based tabs I've had recently the u65 is not fussy about cables.900Supersport
freaktab developer
Just installed and run on mine. Seems to work OK. No interest in football cannot comment further.900Supersport
freaktab developer
I just flash from spflashtool, select the recovery you want and flash. If you want to change to either 4 or 6 gigs for internal storage then do this sooner rather than later.
I've found market helper can be useful if you find some apps are not available (restart, use market helper to change to a 'nexus' and when its done check play store.900Supersport
freaktab developer
Hello. I have new 9x white 16gb, but antutu score is 27k only. Hmm, why? On web, youtube there is over 42k. Any advice to reach 42k and more? I have stock rom v1.3 20140527.
Second problem, on ofic web www.51cube.com is info that inside is camera with F2.0 but i check it and it is F2.4 only. Hmm.
Thanks for help.
Foony.
The 40k scores where cheats. Antutu has been updated to avoid this cheat and so produce a genuine score of 27 to 28k. No idea re the camera.
What I would say is that the 9x is a great tab, its a shame about the misleading claims re performance.900Supersport
freaktab developer
Thanks for clear situation. So ofifcial web is cheating every customer? There is info that this new proc is fast and antutu is over 40k. Even on lcd display folie is mark wit advantages and there is info about 40k antutu too.
But tablet is verry nice, perfect, clear display.... fast and sensitive wifi + gps. I will try your rom later of course.
Which is the best way to root it? Framsroot not working.
Best way is either to flash a custom recovery and then root from that or just flash my ROM.900Supersport
freaktab developer
AW: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 4 July 2014
Originally posted by 900supersport View PostI just flash from spflashtool, select the recovery you want and flash. If you want to change to either 4 or 6 gigs for internal storage then do this sooner rather than later.
Gesendet von meinem SM-N9005 mit Tapatalk
Rockabilly See post 46900Supersport
freaktab developer
There are currently 1975 users online. 0 members and 1975 guests.
