CUBE TALK 9X CUSTOM ROM BASED ON STOCK FIRMWARE 1.8
    Originally posted by bloommax View Post
    fastboot erase userdata
    ******** Did you mean to fastboot format this partition?
    erasing 'userdata'...
    edit : fastboot erase userdata did nothing after an hour or so, i don't event know if it realy started...
    fastboot restart works like a charm, so fastboot seems ok, i don't know what's wrong.
      Re: CUBE TALK 9X CUSTOM ROM BASED ON STOCK FIRMWARE 1.8
      It's been a few (about 10) minutes since i ran it (i did not have a chance to answer the question, btw), do you know how long it is expected to last ? Longer than wiping from recovery ?
      In an other shell window :
      >fastboot devices
      55********** fastboot
      Seems that my device is seen, isn't it ?
      Yes. 'fastboot devices' showed that your device was connected. Did you get any error or completion message? Should not take that long...
        Cube Australia
        Hi all ,
        I've just emailed Cube Australia to ask for their input / suggestions re: this thread and cool ui v3 screen issue after flash.
        They've been very helpful with prompt replies & support, even outside of normal business hours. Highly recommended !
        Sent from my: Sub-ether enabled , paperless virtual waffle iron.
          Re : CUBE TALK 9X CUSTOM ROM BASED ON STOCK FIRMWARE 1.8
          Originally posted by zvoddy23 View Post
          Hi all ,
          Tanks a lot !!!
            kernel
            dejan1979 did you modify the kernel too?
            I'm interested in putting my hands inside the kernel to mod frequency/voltages of the CPU (to increase battery duration and/or performances), but 'till now I'm still studying how to do that, because I was able to do this trick easily with RK3188, here the story is different...
            Otherwise could you enable voltage modding into the kernel to be used at least with trickster mod?
              touchscreen issues
              I find quite disturbing that 2 users lost the use of touchscreen after flashing new Roms. Both were using SS rom before.
              Dejan , which Rom were you using prior to flashing your own ?
                I agree with you!
                I'm worried to install this rom at the moment, also because stock rom is working really well now!
                  Originally posted by giouncino View Post
                  I agree with you!
                  I was using stock rom from cube site. Then i flashed bryan`s custom 1.8 rom....But for the stability i flashed back to the stock china firmware. Only changed language under setting tab.
                  I have nexus 5. I like pure AOSP style phone.
                  When i created this rom i wanted to have same look as my Nexus 5 phone. This is why i integrated Stock Google apps. All of them are working but the Google Chrome. This is Cube bug and i can`t fix it. Everything works fine.
                  I did it and i dont have any problems with it.
                  Check out the video here https://www.youtube.com/watch?v=P3QR...XTT3eDI5SYI9lQ
                    Please set you video to public.
                      Done!!!
                        downloading your rom. Will try and report
                          After flashing touchscreen does not work anymore. Can't go into recovery...
                          Hi pix64, with model of your tablet ?(32GB-16GB,black or white)
                            Hi !
                            It's black 32 GB.
                            News : after i let the tablet charge overnight (when flashing dejan's zip yesterday, it was about 70%), bootloop has gone and i can do normal boot and recovery.
                            But nothing has changed regarding the touchscreen, it does not work neither with stock nor 900ss rom, nor in recovery.
                            I got RUA1 CWM working, as it uses hardware buttons, but there's no use if touchscreen does not work.
                            EDIT : Flashed Dejan's rom from CWM (no touchscreen, no TWRP), everything went fine, it boots fine, but still no touchscreen.
                            I don't know if this could be useful, but it was the first time i flashed a rom from recovery on this tablet, previous flashes (stock, 900ss, 1.6 and 1.8) were with flash tool.
                            Thanks guys !
                              Hi !
                              It's black 32 GB.
                              Thanks guys !
                              Seller from aliexpress told me,
                              Talk 9x have 2 version ,one is 16G version ,the order is 32G version
                              16G version have black and white color
                              but 32G version only has black color,
                              touch screen of the black and white are different" (display is same)
                              black one is more expensive.
                                Ok I flashed your rom. I used the stock cwm ( not lepi twrm ) and all is fine . touchscreen and everything else working perfectly. Will now evaluate the rom.
                                I have talk 9x 16g
                                Phil
