CUBE TALK 9X CUSTOM ROM BASED ON STOCK FIRMWARE 1.8
I managed to restore IMEI, and my latest TWRP backup using TWRP manager. But still no touchscreen.
I've been googling and read posts about touchscreen firmware, but i didn't find how to interact with it, none of the tools i found could do anything with our touchscreen.
Below is the response I've got , so far , from CUBE AUSTRALIA.
It contains a link to some old Firmware that was shipped with U65GT's to Australia.
We should hear more news from them when I clarify the touch screen issue for them.
I don't think the technician has looked into this yet?
”I have a good news for you. Seems I have solved all the issues.
A bit background first
In Australia market, we have two rom versions, one is the V1.0 which is in your first tablet, and the other is v1.3 which is in your second tablet, technician just simply changed the v1.3 language into English.
Ok, your issues first: 1) Long time boot issue
The V1.0 is a stable version, the long boot issue might be caused by improper recovery by our technician due to different driver installed. So, just re-flash the romv1.0, and the issue should be solved. I have now upload a full firmware package, v1.0 20140528, onto Google Drive, path:https://drive.google.com/file/d/0B8u...it?usp=sharing
This package includes full drivers, rom(v1.0), SP flash tool(should have no difference with other MTK flash tools) and an English Operating Manual! You can now start to download it!
2) Customised v1.8 on your second tablet
All v1.3 Chinese version onward are customised to serve the Chinese market, they have certain bundle apps installed. It is not recommended to be used. Therefore I suggest you to flash it back to v1.0.
Now, issues on Freaktab forum 1) Cool ui v3 black screen issue
This should be caused by a) the missing file in the rom package, and most important reason b) the drivers. Please see my V1.0 package, in which there is a full package of drivers for MTK8392/6592 in Windows XP/Vista/Win7/Win8-32bit/64bit. Now, how to recovery the 'dead' tablet:
a) connect the tablet with your PC by USB cable
b) open 'Device Manager', there should be an 'unknown device' showed up
c) install the drivers for this device by selecting the RIGHT driver
d) the driver should now be installed and the device is shown in 'Port (COM and LPT)' and the device name might be 'MTK xxxx port'
e) now you can flash the device under the normal step......
f) finger crossed...
In conclusion
All the issues above are most likely due to wrong MTK driver installed. Once you installed the right driver on your computer, it should be OK to flash any rom. This can also explain why you cannot use flash tools at first time. Also, to all 9x users, we suggest you install v1.0 only at the moment. Once we have the later Official English version for 9x, I believe it should have, we will release it any let your guys know at first instance. Meanwhile, if you find any issue in using v1.0, please let us know, we will improve it.
Hope this can help.
Cheers,
Cube Australia
P.S. I double checked the package, there is a bit Chinese character in the folder name, you can delete it if you fell a bit annoy, shall have no impact on anything."
Frpm my chinese i got the app called MTKTweak.apk/ It is in chinese. Can anyone help me translate or point to the tool to do the job for me.
App is made for the control of 8core cpu and gpu parameters mt6592.
For batter performance and better gaming or battery saver.
I have apk and 4 init.d scripts for it. It is MTWtweakv16.
Any help is much appreciated
I try all the translating tools from the xda developers site and it did not work.
there is a translated version here, you can try it
Thanks for reply. But from this miui post its an older v14 version. V15 is designed for our mtk6592 soc. V14 kinda is working but thats not it. Tx anyway
Does it support overclock/underclock? Send me a downtown link of the Chinese version if so. I will translate it into English if it is useful.
I dont know is that option available. I am not sure. I can`t read chinese. I know it is usefull and it can control many different options configured for mt6592 SOC. I will upload it on my google drive right now.
Help me translate it. Thank you
Translate it and upload it back please
Here is the gdrive link https://drive.google.com/file/d/0B5z...it?usp=sharing
Re: CUBE TALK 9X CUSTOM ROM BASED ON STOCK FIRMWARE 1.8
Just back from holidays and catching up on things. It sounds as though a couple of people have now got issues with the touch screen after flashing this or the coolui ROM linked from cubes site.
If you can send me some details of the devices you have, maybe including the serial numbers (by pm if you wish) I'll email my contact at cube and see if I can get any hep from them.
