format("ext4", "EMMC", "/dev/block/mmcblk0p5", "0", "/system"); mount("ext4", "EMMC", "/dev/block/mmcblk0p5", "/system"); ui_print(">>> Copy Files"); package_extract_dir("system", "/system"); mount("ext4", "EMMC", "/dev/block/mmcblk0p7", "/data"); package_extract_dir("data", "/data");
CUBE TALK 9X CUSTOM ROM BASED ON STOCK FIRMWARE 1.8
Originally posted by mmrrdd View Post
Code:
Originally posted by Lepi View PostThanks, I'll try it. But that's part of my script for my TWRP and CWM
Code:format("ext4", "EMMC", "/dev/block/mmcblk0p5", "0", "/system"); mount("ext4", "EMMC", "/dev/block/mmcblk0p5", "/system"); ui_print(">>> Copy Files"); package_extract_dir("system", "/system"); mount("ext4", "EMMC", "/dev/block/mmcblk0p7", "/data"); package_extract_dir("data", "/data");
"/system" should to be "/dev/block/mmcblk0p6 "
"/dev/block/mmcblk0p6" is the real system partition
Originally posted by mmrrdd View Postif you see in "update-scrip" file (from factory stock firmware)
R: CUBE TALK 9X CUSTOM ROM BASED ON STOCK FIRMWARE 1.8
Originally posted by Rara Avis View PostWell, can anybody with access to the tablet show the output of
Code:cat /proc/dumchar_info
Part_Name************************************ Size****************** StartAddr************************************ Type****************** MapTo************ Region
preloader****************** 0x0000000000040000************ 0x0000000000000000************ 2************ /dev/misc-sd************************ BOOT_1
mbr*********************************************** ******* 0x0000000000080000************ 0x0000000000000000************ 2************ /dev/block/mmcblk0************************ USER
ebr1********************************************** ** 0x0000000000080000************ 0x0000000000080000************ 2************ /dev/block/mmcblk0p1************ USER
pro_info************************ 0x0000000000300000************ 0x0000000000100000************ 2************ /dev/block/mmcblk0************************ USER
nvram****************************************** 0x0000000000500000************ 0x0000000000400000************ 2************ /dev/block/mmcblk0************************ USER
protect_f****************** 0x0000000000a00000************ 0x0000000000900000************ 2************ /dev/block/mmcblk0p2************ USER
protect_s****************** 0x0000000000a00000************ 0x0000000001300000************ 2************ /dev/block/mmcblk0p3************ USER
seccfg************************************ 0x0000000000040000************ 0x0000000001d00000************ 2************ /dev/block/mmcblk0************************ USER
uboot****************************************** 0x0000000000060000************ 0x0000000001d40000************ 2************ /dev/block/mmcblk0************************ USER
bootimg****************************** 0x0000000000a00000************ 0x0000000001da0000************ 2************ /dev/block/mmcblk0************************ USER
recovery************************ 0x0000000000a00000************ 0x00000000027a0000************ 2************ /dev/block/mmcblk0************************ USER
sec_ro************************************ 0x0000000000600000************ 0x00000000031a0000************ 2************ /dev/block/mmcblk0p4************ USER
misc********************************************** ** 0x0000000000080000************ 0x00000000037a0000************ 2************ /dev/block/mmcblk0************************ USER
logo********************************************** ** 0x0000000000800000************ 0x0000000003820000************ 2************ /dev/block/mmcblk0************************ USER
ebr2********************************************** ** 0x0000000000080000************ 0x0000000004020000************ 2************ /dev/block/mmcblk0************************ USER
expdb****************************************** 0x0000000000f60000************ 0x00000000040a0000************ 2************ /dev/block/mmcblk0************************ USER
android****************************** 0x0000000080000000************ 0x0000000005000000************ 2************ /dev/block/mmcblk0p5************ USER
cache****************************************** 0x0000000008000000************ 0x0000000085000000************ 2************ /dev/block/mmcblk0p6************ USER
usrdata****************************** 0x0000000080000000************ 0x000000008d000000************ 2************ /dev/block/mmcblk0p7************ USER
fat*********************************************** ******* 0x0000000639700000************ 0x000000010d000000************ 2************ /dev/block/mmcblk0p8************ USER
bmtpool****************************** 0x0000000000000000************ 0x00000000ffff00a8************ 2************ /dev/block/mmcblk0************************ USER
Part_Name:Partition name you should open;
Size:size of partition
StartAddr:Start Address of partition;
Type:Type of partition(MTD=1,EMMC=2)
MapTo:actual device you operate
u0_a193@U65GT:/ $
Note: attention, my tablet is with 13.5gb of data partition
(talk9x 32gb black serialcode n. 1423)
QED!
UPD
Before I began to edit the updater-script, I looked the locations of data in the memory sections through Root explorer.
As expected:Code:android****************************** 0x0000000080000000************ 0x0000000005000000************ 2************ /dev/block/mmcblk0p5************ USER
Code:cache****************************************** 0x0000000008000000************ 0x0000000085000000************ 2************ /dev/block/mmcblk0p6************ USER
Originally posted by Rara Avis View PostAs expected:Code:android****************************** 0x0000000080000000************ 0x0000000005000000************ 2************ /dev/block/mmcblk0p5************ USER
when it is
adb dumchar_info,maybe can not directly to detec the hardware device( harddisk),
real system partition is "/dev/block/mmcblk0p6" (follow the udate-script command).
Originally posted by Lepi View PostI've known about it. Do you think that the error of my touchscreen linked to this markings?
will work after the first boot of flashed new firmware ,
it will take a long time to start a device,
result-setting-data may be stored on another hidden partition
(depending on link-pointer in uboot,kernel(recovery and boot image),
and ebr,etc(/dev/pro_info, /dev/protect_f, /dev/protect_s , /dev/seccfg ,
/dev/misc, /dev/expdb ,/dev/bmtpool ))
You should to flash-back to the original(Chinese stock firmware) recovery, boot, ebr1, ebr2,uboot.
and then, flash again with this factory OTA update,
and restore this image to this partition
/dev/pro_info
/dev/protect_f
/dev/protect_s
/dev/seccfg
/dev/misc
/dev/expdb
/dev/bmtpool
by adb commandLast edited by mmrrdd; 21 August 2014, 11:12.
Originally posted by mmrrdd View PostYou should to flash-back to the original(Chinese stock firmware) recovery, boot, ebr1, ebr2,uboot.
/dev/pro_info
/dev/protect_f
/dev/protect_s
/dev/seccfg
/dev/misc
/dev/expdb
/dev/bmtpool
by adb command
Ok, let's see (ADB to Lepi's TWRP):
Code:~ # ls -la / | grep emmc drwxrwxrwx root root 1970-01-01 00:00 emmc [COLOR=#008000]lrwxrwxrwx root root 1970-01-01 00:00 emmc@android -> /dev/block/mmcblk0p5[/COLOR] [COLOR=#ff0000]lrwxrwxrwx root root 1970-01-01 00:00 emmc@cache -> /dev/block/mmcblk0p6[/COLOR] lrwxrwxrwx root root 1970-01-01 00:00 emmc@ebr1 -> /dev/block/mmcblk0p1 lrwxrwxrwx root root 1970-01-01 00:00 emmc@fat -> /dev/block/mmcblk0p8 lrwxrwxrwx root root 1970-01-01 00:00 emmc@protect_f -> /dev/block/mmcblk0p2 lrwxrwxrwx root root 1970-01-01 00:00 emmc@protect_s -> /dev/block/mmcblk0p3 lrwxrwxrwx root root 1970-01-01 00:00 emmc@sec_ro -> /dev/block/mmcblk0p4 lrwxrwxrwx root root 1970-01-01 00:00 emmc@usrdata -> /dev/block/mmcblk0p7 ~ # mount rootfs on / type rootfs (rw) tmpfs on /dev type tmpfs (rw,nosuid,relatime,mode=755) devpts on /dev/pts type devpts (rw,relatime,mode=600) proc on /proc type proc (rw,relatime) sysfs on /sys type sysfs (rw,relatime) [COLOR=#ff0000]/dev/block/mmcblk0p6 on /cache type ext4 (rw,relatime,data=ordered)[/COLOR] /dev/block/mmcblk0p8 on /emmc type vfat (rw,relatime,fmask=0000,dmask=0000,allow_utime=0022,codepage=cp437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro) /dev/block/mmcblk0p8 on /and-sec type vfat (rw,relatime,fmask=0000,dmask=0000,allow_utime=0022,codepage=cp437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro) [COLOR=#ff0000]~ # ls -la /cache drwx------ system system 2013-01-01 11:41 backup drwxrwx--- root root 1970-01-01 00:00 lost+found drwxrwx--- system cache 2014-08-21 12:30 recovery[/COLOR] [COLOR=#008000]~ # mkdir p5 ~ # mount /dev/block/mmcblk0p5 p5 ~ # ls -la p5 drwxr-xr-x root root 2014-08-17 18:04 app drwxr-xr-x root shell 2014-08-17 18:04 bin -rw-r--r-- root root 4024 2014-07-04 12:43 build.prop drwxr-xr-x root root 2014-07-04 12:56 data drwxr-xr-x root root 2014-08-20 16:53 etc drwxr-xr-x root root 2014-07-04 13:09 fonts drwxr-xr-x root root 2014-08-16 05:41 framework drwxr-xr-x root root 2014-07-04 11:31 lib drwx------ root root 1970-01-01 00:00 lost+found drwxr-xr-x root root 2014-07-04 13:02 media drwxr-xr-x root root 2014-07-04 13:02 mobile_toolkit drwxr-xr-x root root 2014-07-04 13:58 priv-app drwxr-xr-x root root 2014-07-04 12:56 res drwxr-xr-x root root 2014-07-04 12:56 thirdparty drwxr-xr-x root root 2014-07-04 12:56 tts drwxr-xr-x root root 2014-07-04 13:01 usr drwxr-xr-x root shell 2014-07-04 11:12 vendor drwxr-xr-x root shell 2014-08-17 18:04 xbin[/COLOR] ~ #
Not to mention that this TWRP (assuming system -> /dev/block/mmcblk0p5) was used for rooting, replacing framework-res.apk etc more than once. Can't imagine success with system mapped improperly.
Thanks for this firmware, but it didn't work better than with the other, nothing happens at all imo.
I've read your other new posts guys, thank you very much for helping.
Recovery partitions messing is interesting, but would be surprising imho.
Would touch screen failure be the only problem if partitions were melt at flashing ? I think system would not boot at all, or we would at least see inconsistent mounts or space left on partitions, don't you think ?
Or i did not understand something.
This morning i finaly had an answer from the store i bought the tablet, it's going for RMA by this weekend... so i think i have to stop trying anything more, and wait patiently it comes back, repaired or exchanged.
Lepi, maybe you could insist with your aliexpress seller and try to get your tablet to RMA too. If it works, you can sell your new tablet.
It's been a long time trying to rise these touch screens back from the dead, many sleepless nights, thanks a million time for helping guys. Thanks a lot.This forum rocks :-)
There are currently 1735 users online. 0 members and 1735 guests.
