FOR ALL OF YOU HAVING PROBLEM WITH TOUCHSCREEN NOT FUNCTIONING AFTER FLASHING MY ROM HERE IS MY FIX.
TESTED ONLY ON CUBE TALK 9X WHITE/BLACK
-Takes only about 20 minutes if you follow this steps
**make sure you have a working backup of nvram.bin from your tablet**
**must be familiar with use of SP FLASH TOOL**
**tablet should be fully charged or at least 40% battery life left**
**Backup all your data from the tablet on the pc**
1.Download first https://drive.google.com/uc?id=0B5za...xport=download
2.Extract downloaded file to your drive c:
3.Open extracted folder and you will see 3 folders inside Drivers,SP FLASH TOOL AND STOCK CHINA FIRMWARE
4.Install the drivers depending of your system X86 or X64.
5.IF YOU RUN WINDOWS 8 .DRIVER SIGNING POLICY MODE MUST BE DISABLED IN ORDER TO INSTALL DRIVERS CORRECTLY OR FLASH TOOL WON`T WORK link here http://thephuck.com/end-user-computi...-in-windows-8/
6. By now you guys should have drivers installed and we can move on
7. Open folder U65GT_V1.8_20140704 STOCK CHINA FIRMWARE and place your copy of nvram.bin
8. Now we are ready for SP FLASH TOOL but before we start make sure the battery is at least 40% charged and make sure all your files from internal memory are saved and transfered to your PC.
9. This proces will erase all data files and partitions from your tablet.
10. Power off the tablet
11.Open folder SP FLASH TOOL MODD
12. Right click on flash_tool.exe RUN AS ADMINISTRATOR
13. Answer Yes in popup window
13. SP FLASH TOOL will start with error message scatter file not found... JUST CLICK OK
14.Click on the box Scatter-Loading and select scatter file from folder U65GT_V1.8_20140704 STOCK CHINA FIRMWARE
15.When the list of files is loaded make sure everything is checked in check box including NVRAM
16. Select Format All+Download
17. Press Download and wait a few seconds
18.Connect your tablet to usb port and wait process to complete
19.When done wait for a minute and power on tablet
20. Thats it you are back on stock china firmware 1.8
21. From here you can flash files throught recovery or whatever else.
I HAVE REMOVED DOWNLOADING LINKS FOR MY FIRMWARE AND WE WILL BE BACK SOON WITH MORE OPTIMISED FIRMWARE AND HOPEFULLY CHROME BUG FIX
