CUBE TALK 9X CUSTOM ROM BASED ON STOCK FIRMWARE 1.8
Originally posted by 900supersport View PostThat's not good reading. I've e-mailed cube and see what they have to say.
Here's hoping.
Brian
It was part of the optimism :-)
And how do you know the name and brand of touchscreen controller? Happen to know?
UPD
I know! Goodix GT928
Tomorrow I will lay out the photo dismantled tablet
R: CUBE TALK 9X CUSTOM ROM BASED ON STOCK FIRMWARE 1.8
Originally posted by Lepi View PostAnd how do you know the name and brand of touchscreen controller? Happen to know?
UPD
check out this article for pipo m9 that had your same problem with same Goodix GT and who then solved ... who knows might help to ... http://www.freaktab.com/showthread.p...n-not-working&Last edited by unanonimo; 16 August 2014, 22:17.
Originally posted by bloommax View PostTheir serive is pretty good. One guy whose touch screen was disabled by ROM flashing received a brand new unit after RMA...
UPD
Found this archive from this page
And this datasheet in english
Originally posted by pix64 View PostOk, i must have read bad pages about chinese warranty in general, not cube in particular. Thank you for keeping positive !
Good job Lepi !
Originally posted by Lepi View PostThank you. I have this pdf, but I do not know a specialist who has a programmer for the controller firmware.
root@U65GT:/ # find / -name gt*
find / -name gt*
/proc/gt9xx_config
/sys/bus/i2c/drivers/gt9xx
# With screen turned on
root@U65GT:/sys/bus/i2c/drivers/gt9xx # cat /proc/gt9xx_config
==== GT9XX config init value====
0x00 0x00 0x06 0x00 0x08 0x0A 0x75 0x10
0x00 0x48 0x19 0x0F 0x64 0x50 0x03 0x03
0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x18
0x1A 0x1E 0x14 0x90 0x30 0xCC 0x19 0x1B
0x5C 0x11 0x00 0x00 0x00 0x02 0x03 0x25
0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x2D 0x46 0x94 0x05 0x02
0x08 0x00 0x00 0xE2 0x6B 0xD2 0xE2 0x6B
0xD2 0xE2 0x6B 0xD2 0xE2 0x6B 0xD2 0xE2
0x6B 0xD2 0x00 0x00 0x00 0x00 0x00 0x00
0x00 0x01 0x04 0x05 0x06 0x07 0x08 0x09
0x0C 0x0D 0x0E 0x0F 0x10 0x11 0x14 0x15
0x16 0x17 0x18 0x19 0x1A 0x1B 0x1C 0x1D
0x00 0x00 0x00 0x00 0x00 0x00 0x19 0x1B
0x1C 0x1E 0x1F 0x20 0x21 0x22 0x23 0x24
0x25 0x26 0x27 0x28 0x29 0x2A 0x14 0x13
0x12 0x11 0x10 0x0F 0x0E 0x0D 0x0C 0x0A
0x08 0x07 0x06 0x04 0x02 0x00 0x00 0x00
0x80 0x01
==== GT9XX config real value====
0x80 0x01
==== GT9XX Version ID ====
PID: 927 VID: 0x1021
==== Touch Status and Clock Gate ====
status: 1: on, 0: off
status:1
# With screen turned off
root@U65GT:/ # cat /proc/gt9xx_config
0x80 0x01
0x00 0x00
PID: VID: 0x0000
status:0
From http://www.goodix.com/products2.asp i see that 927 and 928 have common specifications :
GT927 31x17 QFN68, 8x8 7”~10.1” 10 GT928 32x24 QFN68, 8x8 7”~10.1” 10
Could it be gt927 instead of gt928 ? Can someone with a working touchscreen and who succesfully flashed Dejan's rom tell us if he gets 927 or 928 ?
Not on Dejan's ROM but out of interest my Black 16 GB week 23 device returns a pid of 928.900Supersport
freaktab developer
Re: CUBE TALK 9X CUSTOM ROM BASED ON STOCK FIRMWARE 1.8
Originally posted by zvoddy23 View PostBelow is the response I've got , so far , from CUBE AUSTRALIA.
It contains a link to some old Firmware that was shipped with U65GT's to Australia.
We should hear more news from them when I clarify the touch screen issue for them.
I don't think the technician has looked into this yet?
”I have a good news for you. Seems I have solved all the issues.
A bit background first
In Australia market, we have two rom versions, one is the V1.0 which is in your first tablet, and the other is v1.3 which is in your second tablet, technician just simply changed the v1.3 language into English.
Ok, your issues first:
1) Long time boot issue
The V1.0 is a stable version, the long boot issue might be caused by improper recovery by our technician due to different driver installed. So, just re-flash the romv1.0, and the issue should be solved. I have now upload a full firmware package, v1.0 20140528, onto Google Drive, path:https://drive.google.com/file/d/0B8u...it?usp=sharing
This package includes full drivers, rom(v1.0), SP flash tool(should have no difference with other MTK flash tools) and an English Operating Manual! You can now start to download it!
2) Customised v1.8 on your second tablet
All v1.3 Chinese version onward are customised to serve the Chinese market, they have certain bundle apps installed. It is not recommended to be used. Therefore I suggest you to flash it back to v1.0.
Now, issues on Freaktab forum
1) Cool ui v3 black screen issue
This should be caused by a) the missing file in the rom package, and most important reason b) the drivers. Please see my V1.0 package, in which there is a full package of drivers for MTK8392/6592 in Windows XP/Vista/Win7/Win8-32bit/64bit. Now, how to recovery the 'dead' tablet:
a) connect the tablet with your PC by USB cable
b) open 'Device Manager', there should be an 'unknown device' showed up
c) install the drivers for this device by selecting the RIGHT driver
d) the driver should now be installed and the device is shown in 'Port (COM and LPT)' and the device name might be 'MTK xxxx port'
e) now you can flash the device under the normal step......
f) finger crossed...
In conclusion
All the issues above are most likely due to wrong MTK driver installed. Once you installed the right driver on your computer, it should be OK to flash any rom. This can also explain why you cannot use flash tools at first time. Also, to all 9x users, we suggest you install v1.0 only at the moment. Once we have the later Official English version for 9x, I believe it should have, we will release it any let your guys know at first instance. Meanwhile, if you find any issue in using v1.0, please let us know, we will improve it.
Hope this can help.
Cheers,
Cube Australia
P.S. I double checked the package, there is a bit Chinese character in the folder name, you can delete it if you fell a bit annoy, shall have no impact on anything."
I am interested in getting this tablet. I live in Australia.
A few questions. Where did you but your tablet in Australia?
Does this non China firmware run Chrome?
ACUBE AUSTRALIA
No chrome doesn't work though + I'm not sure what ROM will be installed? you could contact them at >> [email protected] <<
They have been most willing to help with any issue I've had.
Sent from my crappy XP workstation.
Originally posted by zvoddy23 View PostHere's a link to the the E-bay seller's shop >> http://www.****.com.au/sch/acubeaust...1&_ipg=&_from= <<
Sent from my crappy XP workstation.if you appreciate my efforts this is the link for any donation:
Originally posted by pix64 View PostLepi, have you tried this command ? What PID value do you get ?
Thanks !
There are currently 3351 users online. 0 members and 3351 guests.
