CUBE TALK 9X CUSTOM ROM BASED ON STOCK FIRMWARE 1.8
    Originally posted by Lepi View Post
    can't execute: Is a directory 126
    /proc/gt9xx_config is a directory ? it's a bit strange
      root@U65GT:/ # /proc/gt9xx_config
      /proc/gt9xx_config
      /system/bin/sh: /proc/gt9xx_config: can't execute: Permission denied
      126|root@U65GT:/ # /sys/bus/i2c/drivers/gt9xx/ # cat /proc/gt9xx_config
      /system/bin/sh: /sys/bus/i2c/drivers/gt9xx/: can't execute: Is a directory
      126|root@U65GT:/ #
      videoTutor1 videoTutor2 videoTutor3 videoTutor4 videoTutor5 videoTutor6
      TWRP_2.8.1.0
      TWRP_2810_newTheme TWRP_2.8.5.0
      PayPal donate WMID410517421626
        /proc/gt9xx_config
        126|root@U65GT:/ #
        you do not need to be in /sys/bus/i2c/drivers/gt9xx directory, i was at the moment i tried but it's not needed.
        Just to be sure, you only typed the folowing command in a shell ? :
        EDIT : i get the same as you if i paste the whole line and not only the command "cat ..."
          126|root@U65GT:/ # cat/proc/gt9xx_config
          /system/bin/sh: cat/proc/gt9xx_config: not found
          127|root@U65GT:/ # cat /proc/gt9xx_config
          ==== GT9XX config init value====
          0x00 0x00 0x06 0x00 0x08 0x0A 0x75 0x10
          0x00 0x48 0x19 0x0F 0x64 0x50 0x03 0x03
          0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x18
          0x1A 0x1E 0x14 0x90 0x30 0xCC 0x19 0x1B
          0x5C 0x11 0x00 0x00 0x00 0x02 0x03 0x25
          0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
          0x00 0x00 0x00 0x2D 0x46 0x94 0x05 0x02
          0x08 0x00 0x00 0xE2 0x6B 0xD2 0xE2 0x6B
          0xD2 0xE2 0x6B 0xD2 0xE2 0x6B 0xD2 0xE2
          0x6B 0xD2 0x00 0x00 0x00 0x00 0x00 0x00
          0x00 0x01 0x04 0x05 0x06 0x07 0x08 0x09
          0x0C 0x0D 0x0E 0x0F 0x10 0x11 0x14 0x15
          0x16 0x17 0x18 0x19 0x1A 0x1B 0x1C 0x1D
          0x00 0x00 0x00 0x00 0x00 0x00 0x19 0x1B
          0x1C 0x1E 0x1F 0x20 0x21 0x22 0x23 0x24
          0x25 0x26 0x27 0x28 0x29 0x2A 0x14 0x13
          0x12 0x11 0x10 0x0F 0x0E 0x0D 0x0C 0x0A
          0x08 0x07 0x06 0x04 0x02 0x00 0x00 0x00
          0x80 0x01
          ==== GT9XX config real value====
          0x00 0x00
          ==== GT9XX Version ID ====
          PID: VID: 0x0000
          ==== Touch Status and Clock Gate ====
          status: 1: on, 0 ff
          status:0
          root@U65GT:/ #
          TWRP_2.8.1.0
            127|root@U65GT:/ #
            try adding a space between cat and /proc/gt9xx_config
              PID: VID: 0x0000
              status: 1: on, 0 ff
              status:0
              root@U65GT:/ #
              that's what you get when the screen is off, if you type the command while screen is on, you will get PID.
                0x80 0x01
                0x80 0x01
                PID: 927 VID: 0x1021
                status: 1: on, 0 ff
                status:1
                root@U65GT:/ #
                TWRP_2.8.1.0
                  Ok, so you get 927 too.
                  Just to be sure : did you open your tablet yourself and take the photos you posted showing GT928 chip ?
                    this is a picture of my tablet and my chip
                    or I misunderstood your question?
                    TWRP_2.8.1.0
                      If it can help you to compare the results with my tablet with a touchscreen running below I place the result to the command CAT out directly from Android terminal emulator
                      u0_a193@U65GT:/ $ su
                      0x80 0x01
                      0x41 0x00 0x06 0x00 0x08 0x0A 0x75 0x10
                      0x3F 0x00
                      PID: 928****** VID: 0x1040
                      status: 1: on, 0 ff
                      status:1
                      root@U65GT:/ #
                        You understood well, i wanted to be sure I did understand your photos
                        So you/we have a GT928 hardware chip, but if i'm right it seems to be seen as a GT927, in a software way.
                        900supersport gets PID=928 with his working tablet built the same week as your, 1 week before mine.
                          have a solution?
                          TWRP_2.8.1.0
                            Thanks !
                            So init values are the same, real values, PID and VID are different :
                            Tablet with touch screen working :
                            0x3F 0x00
                            Tablet with touch screen not working :
                            0x80 0x01
                              R: CUBE TALK 9X CUSTOM ROM BASED ON STOCK FIRMWARE 1.8
                              Thanks !
                              0x3F 0x00
                              0x80 0x01
                              My tablet is made in the same week Lepi's tablet.
                              My sn is u65gt32gb1423xxxxxxx vers.black
                              Sante (aka instancabile / uNaNONIMO)
                                have a solution?
                                You would already know if i had :-)
                                I don't know how to modify the config, even temporarily.
                                As touch screen is not working in recovery, i think the GT928 firmware/config may have been overwritten with a bad one. I have read that touch screen firmware and config are stored in the chip itself (or in something related to the chip), not in the eMMC.
                                But i've read a lot of things recently and may have either misunderstood or read something that is not related to this goodix chip. This only a thought.
