MK808B KitKat kernel [Working WiFi & BT]
    thank you for your response and what do you mean(Wait for Android to boot.)?????
    and what time for waiting android to boat
      It shouldn't take more then a half minute. If it takes longer, it's possible that something went wrong during the flashing process. Please read my instructions here.
      iMito QX1 KitKat 4.4.2 ROM
      MK808B (RK903) KitKat kernel builds
      MK808B (RK903) KitKat kernel sources
        Hello,
        Any way to keep CPU above 1GHz? It just stays between 800-1000MHz no matter which governor I choose... Maybe an overclock kernel?
          Is it possible to create a ubuntu build based on this kernel? (like from this one just with working wifi: http://freaktab.com/forum/tv-player-...04-for-mk808)?
            I'm looking forward to this. Maybe a linux wizard can show us?
              BalintBanyasz loads of thanks to you.
              Installed with fixed wifi kernel. Works good so far.
              Again thanks a lot for ur effort
