MK808B KitKat kernel [Working WiFi & BT]
Originally posted by triplesilk View PostCan someone tell me if there is a working KitKat rom for the non B mk808? It's been mentioned but I cant see one anywhere. I realise that it wouldn't be perfect, but my mk808 needs a new rom and based on how much faster the minix x7 is with kitkat I'm crossing my fingers that one exists.
Originally posted by BalintBanyasz View PostYes, try Dumonde's KitKat from the first post or mo123's from this thread.
Originally posted by triplesilk View PostThanks man. I'll try one and report back how it works.
Originally posted by BalintBanyasz View PostRemember to always flash the loader that comes with the ROM when upgrading from JellyBean to Kitkat or going back to JellyBean because KitKat uses a new bootloader that is incompatible with JellyBean. Use the latest AndroidTool v2.1.
Originally posted by triplesilk View PostCan someone tell me if there is a working KitKat rom for the non B mk808? It's been mentioned but I cant see one anywhere. I realise that it wouldn't be perfect, but my mk808 needs a new rom and based on how much faster the minix x7 is with kitkat I'm crossing my fingers that one exists.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View PostIf you dont need wifi you can flash quite a few of them.
I do need wifi and have the mk808 non B so I'm a bit confused. With the Minix X7 the new roms I've used have been image files. With this, do I need a rom and kernel to work together? The kernals seem to have a B in so I kind of assumed that they wouldn't work.
Originally posted by triplesilk View PostThanks both, very helpful.
I do need wifi and have the mk808 non B so I'm a bit confused. With the Minix X7 the new roms I've used have been image files. With this, do I need a rom and kernel to work together? The kernals seem to have a B in so I kind of assumed that they wouldn't work.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
KitKat ROM for new MK808b RTL8723
Hi everybody,
I was wondering if there is any good KitKat ROM available for the new MK808B / RK3066 using RTL8723BS chipset.
I tried the existing ROMs, but none of them works. Also, I have noticed the download link for the Dumonde's MK808 ROM is not valid anymore. Is there a mirror or a different location from which I can download that ROM ?
Thank you
MK808B v5 (RTL8723BS) kernel
Thank you
2. Flash my new MK808B v5 (RTL8723BS) kernel:
kernel_mk808b_v5_kk.zip
I have the original MK808B (RK903) so I could't test this kernel.
Originally posted by Eriander View PostThank you for the answer.
I tried the ROM and the kernel, but unfortunately I only got 2 penguins.- install Terminal Emulator
- run the following commands:
- su
- dmesg > /sdcard/dmesg_v5.txt
- attach the dmesg_v5.txt located on the sdcard
In this kernel I've only changed WiFi from RK903 to RTL8723BS SDIO. Perhaps the dmesg could shed some light on the problem.
Originally posted by gurzo82 View PostCould you do a version of this new kernel with support for usb wifi rtl8192cu ? thanks
Real 1080p
Can someone verify this (I don't have a 1080p screen)?
- Flash Dumonde's KitKat ROM
- Flash my 1080p kernel (link in my previous post)
- Install Build Prop Editor from Play
- Change video.use.overlay from 1 to 0
- Reboot
This should activate real 1080p output according to some threads.Last edited by BalintBanyasz; 11 November 2014, 23:08.
There are currently 1522 users online. 1 members and 1521 guests.
