MK808B KitKat kernel [Working WiFi & BT]
Originally posted by BalintBanyasz View PostHere is an updated kernel with the power indicator LED enabled:
[ATTACH]7715[/ATTACH]
The wifi bug is still present
I tried to do that but wifi doesn't load, maybe need to insmod bcmhd.ko & rkwifi.ko at boottime?
Also tried to use a newer wifi driver, but can't turn wifi on with that in Android settings.
Originally posted by mo123 View PostHave you tried to compile bcmhd, rkwifi driver as a module instead of build-in to the kernel?
It looks like Karel has a working KitKat kernel for Minix Neo X5 (RK903 WiFi). He is using the same linux-rockchip sources that we do. I've sent him a pm but he hasn't replied yet.
Originally posted by BalintBanyasz View PostI'll try that. Could you share the link to the newer wifi drivers? I've compared the driver sources in 3.0.8 (omagamoon), 3.0.36 (SDK) and 3.0.36 (KitKat) and they all seem to use the same version.
excuse me derangement of .but after 16 months of finless 1.7 and 2.1. I decide to move to the kit kat:
Download and install
• MK808 Dumonde ROM (rooted) android in one small corner of my tv
• Kit Kat Shomari 4.4.2 RK3066 2 penguins
• Smallart Uhost2 KitKat (U2.442.000.11.140327) 2 penguins
MK808 / B KitKat ROM (No wifi) 2 penguins
the problem I always two penguins
My stick is rk903 mk808b original 5v 2A original 2000MA never had problems I reinstall the finless 2.1 not one problem
2) how to install MK808B KitKat core [WiFi and BT work] of
BalintBanyasz
BalintBanyasz. writing I flashed the kernel using the RkFlashKit utility. ok.
RkFlashKit do not recognize the image even after the kernel_mk808b_kk.zip dezip rk30_dongle_mtk_4.4_140617 recognize it. or. update. U2.442.000.11.140327
Thank you in advance for your help
English translation of the french google
BalintBanyasz
English translation of the french google- Download AndroidTool v2.1
- If you have a single img firmware
- Switch to the Upgrade Firmware tab
- Select the img file by clicking on the Firmware button
- Click on Update button to start flashing the firmware
- Wait for the flashing process to complete. The device will reboot automatically and boot Android. You have to unplug your device and then put it in flash mode again.
- Switch to the Download Image tab. Uncheck everything except kernel. Select my kernel image by clicking on the empty space in the last column of the kernel row.
- Click Run to replace the original kernel with my kernel.
- If you have a ROM with multiple img files
- Set loader.bin and each img file that came with your ROM. Choose my kernel.img instead of the original
- Click Run to start flashing the firmware
- Switch to the Download Image tab. Select my kernel image by clicking on the empty space in the last column of the kernel row.
Originally posted by rk903 View PostThis is exactly how I did install the images on my Mk808b. Two penguins is all I got... I will try again next week with the new kernel.
Originally posted by BalintBanyasz View PostHave you tried running LowerFormat (Download Image) or EraseFlash (Upgrade Firmware) before flashing the KitKat firmware? Also, make sure that in Download Image mode you select the new KitKat loader (e.g. RK30xxLoader(L)_V2.13.bin). Loaders from previous Android ROMs won't be able to boot KitKat.
yes and yes.
Originally posted by rk903 View PostHi,
yes and yes.
So you and totor54 weren't able to boot KitKat. Did you buy your MK808B from Geekbuying? If so, when?
For all: if you've tested the kernel with a KitKat ROM on your original MK808B with RK903 WiFi/BT please leave a feedback.Last edited by BalintBanyasz; 31 August 2014, 10:55.
Firstly I rooted the U2 rom. Then I flashed the rom with your 1080p kernel and it was booting. Even picuntu was running after reflash recovery partition.
I also flashed the 720p but no boot. Since then I get download errors with rkFlashtool.
So i guess the nand of my MK808B 903 is gone forever but I guess it was not a bad rom but a 100 times flashed nand...
after dozens of tests and hundreds of penguins. Today I came over to put my stick in the background Any user devices. I had to make a mess with the trombone. thank you for your help advise me that buying a place of mk808b
There are currently 2174 users online. 1 members and 2173 guests.
