MK808B KitKat kernel [Working WiFi & BT]
Originally posted by totor54 View Postזרקתי כבר . שמח לקרוא עברית. שלום לך happy to read Hebrew. I speak the french and hebrew. I threw. with cheap. why keep it. if Tronsmart Vega s89 h is good. I intend to buy 2 for my children. goodbye and shalom
I am all hope that this KitKat version will be fixed soon so the WiFi will not "kill" the box.
Originally posted by tecfan69 View PostThanks for that.
As mentioned i build not a KitKat but ubuntu kernel. At line 76 i tried GPIO3_A0 and
RK30_PIN3_PD0 without success. dmesg said failure power on wifi.
What i do not understand is how to get the values that triggers these pins.
I tried a 802IV ap6210 kernel compiled from other sources but this one uses firmware and modules of picuntu 4.5 and bin files located in /system/etc/firmware. There's also rkwifi.ko that has to be loaded. This kernel seems to work. iwconfig gives wlan(0) but all values are not set. Besides wifi powered off at the end of dmesg.
did you have a look at it? Should i PM you?
Thanks for your help.
RKwifi.ko is used for AP6210.
Use http://www.freaktab.com/showthread.p...n-more-devices to make Dmesg dump with included GPIO pin numbers.
Originally posted by mo123 View PostDo you have all the correct modules in system/lib/modules and firmware files in system/etc/firmware?
Kernel boots and all is ok. But no wifi.
So i compiled current alok source but i did not get rkwifi.ko as a module. If i try to load the modules from sgjava with my kernel it fails even both are 3.0.36+ versions.
I used this tool by leolas so you should have a correct gpio dump.
Originally posted by tecfan69 View PostFirstly i tried this kernel, modules and additional files https://github.com/sgjava/ubuntu-min.../master/rk3188.
I used this tool by leolas so you should have a correct gpio dump.Code:[TABLE="class: highlight tab-size-8 js-file-line-container"] [TR] [TD="class: blob-code js-file-line"]#elif defined(CONFIG_BCM4329) || defined(CONFIG_BCM4319) || defined(CONFIG_RKWIFI) \ [/TD] [/TR] [TR] [TD="class: blob-code js-file-line"] || defined(CONFIG_RTL8189ES) || defined(CONFIG_RTL8723BS)[/TD] [/TR] [TR] [TD="class: blob-code js-file-line"][/TD] [/TR] [TR] [TD="class: blob-code js-file-line"] #define RK30SDK_WIFI_GPIO_POWER_N RK30_PIN3_PD0[/TD] [/TR] [TR] [TD="class: blob-code js-file-line"] #define RK30SDK_WIFI_GPIO_POWER_ENABLE_VALUE GPIO_HIGH[/TD] [/TR] [TR] [TD="class: blob-code js-file-line"][/TD] [/TR] [TR] [TD="class: blob-code js-file-line"] #define RK30SDK_WIFI_GPIO_RESET_N RK30_PIN2_PA7[/TD] [/TR] [TR] [TD="class: blob-code js-file-line"] #define RK30SDK_WIFI_GPIO_RESET_ENABLE_VALUE GPIO_HIGH[/TD] [/TR] [TR] [TD="class: blob-code js-file-line"][/TD] [/TR] [TR] [TD="class: blob-code js-file-line"] #define RK30SDK_WIFI_GPIO_WIFI_INT_B RK30_PIN3_PD1 //or try RK30_PIN3_PC6 [/TD] [/TR] [TR] [TD="class: blob-code js-file-line"] #define RK30SDK_WIFI_GPIO_WIFI_INT_B_ENABLE_VALUE GPIO_HIGH[/TD] [/TR] [/TABLE]
In terminal emulator app, type 'su' them 'dmesg' when wifi is turned on.
Originally posted by mo123 View PostIt should look likeCode:[TABLE="class: highlight tab-size-8 js-file-line-container"] [TR] [TD="class: blob-code js-file-line"]#elif defined(CONFIG_BCM4329) || defined(CONFIG_BCM4319) || defined(CONFIG_RKWIFI) \[/TD] [/TR] [TR] [TD="class: blob-code js-file-line"] || defined(CONFIG_RTL8189ES) || defined(CONFIG_RTL8723BS)[/TD] [/TR] [TR] [TD="class: blob-code js-file-line"][/TD] [/TR] [TR] [TD="class: blob-code js-file-line"] #define RK30SDK_WIFI_GPIO_POWER_N RK30_PIN3_PD0[/TD] [/TR] [TR] [TD="class: blob-code js-file-line"] #define RK30SDK_WIFI_GPIO_POWER_ENABLE_VALUE GPIO_HIGH[/TD] [/TR] [TR] [TD="class: blob-code js-file-line"][/TD] [/TR] [TR] [TD="class: blob-code js-file-line"] #define RK30SDK_WIFI_GPIO_RESET_N RK30_PIN2_PA7[/TD] [/TR] [TR] [TD="class: blob-code js-file-line"] #define RK30SDK_WIFI_GPIO_RESET_ENABLE_VALUE GPIO_HIGH[/TD] [/TR] [TR] [TD="class: blob-code js-file-line"][/TD] [/TR] [TR] [TD="class: blob-code js-file-line"] #define RK30SDK_WIFI_GPIO_WIFI_INT_B RK30_PIN3_PD1 //or try RK30_PIN3_PC6[/TD] [/TR] [TR] [TD="class: blob-code js-file-line"] #define RK30SDK_WIFI_GPIO_WIFI_INT_B_ENABLE_VALUE GPIO_HIGH[/TD] [/TR] [/TABLE]
In terminal emulator app, type 'su' them 'dmesg' when wifi is turned on.Attached Files
Hi Mo123,
hope you can help again.
I have wifi running but it looses lots of rx packages. So it's not really useable. I tried different rkwifi.ko modules but the only one that works is that one i downloaded from the ubuntu mini web site. If i try to load any of several kitkat roms it loads but get a wpa_supplicant stack printed onto the terminal. when i check lsmod wlan is loaded but no ping possible.
Do i something wrong with that very nice thing ??
I try this kernel with Shomari ROM, it fix the blinking screen (I think the initial setup screen), but I don't have BT. My device is an original MK808B and I have MK3066 and RK903 chipsets.
Also how can I ennable my 8192 (ko) usb device in this rom ??? just copy and paste ??? the kernel supports this driver/usb device ??
EDIT1: Nope, coping the rk8192.ko file ins modules and sdcard does'nt enable the USB-WiFi, still have 65Mbps from internal wifi.
¿Anyone have the driver for 8192.ko for this kernel/rom?
Best regards.
8192cu module
Originally posted by Lokotito View PostI try this kernel with Shomari ROM, it fix the blinking screen (I think the initial setup screen), but I don't have BT. My device is an original MK808B and I have MK3066 and RK903 chipsets.
Best regards.
2) I've compiled a 8192cu.ko for you - 8192cu.zip.
Here is a quick guide to enable it (from ArmTvTech):
enable /system write: adb remount . or mount -o rw,remount /system in terminal emulator.
push it to mk808: adb push rtl8192cu.ko /system/lib/modules.
and insmod: insmod /system/lib/modules/rtl8192cu.ko.
disable wifi in android settings->wifi
plugin wifi adapter then reenable wifi in android wifi settings.Last edited by BalintBanyasz; 15 September 2014, 22:25.
Mo123,
what rkwifi module do you use on a 3188 kernel? As mentioned, all of the original roms causes oops. I tried the only module that works but get problems with 80211 config. Any experience on that?
Thanks for the android firmware link in another post. That one is the best i tried so far.
There are currently 1833 users online. 0 members and 1833 guests.
