MK808B KitKat kernel [Working WiFi & BT]
Originally posted by tecfan69 View PostFirstly I rooted the U2 rom. Then I flashed the rom with your 1080p kernel and it was booting. Even picuntu was running after reflash recovery partition.
I also flashed the 720p but no boot. Since then I get download errors with rkFlashtool.
So i guess the nand of my MK808B 903 is gone forever but I guess it was not a bad rom but a 100 times flashed nand...
Originally posted by BalintBanyasz View PostTronsmart Vega S89 seems to be the best Android TV box you can get right now. It's way faster than the RK3066/RK3188 devices. You can also find cheaper boxes with the same SoC (AML S802) but Tronsmart and Minix have the best build quality.
thank you for your help. I do not understand the difference between the 3 models that you advise me thank you in advance
Tronsmart Vega S89-S802 Amlogic H-H $ 120
Tronsmart Vega S89 S802 Elite Amlogic $ 99
Tronsmart Vega Amlogic S802 S89 $ 110
the price does not matter
Originally posted by totor54 View Postthank you for your help. I do not understand the difference between the 3 models that you advise me thank you in advance
Vega S89 Elite Vega S89 Vega S89-H Storage 8GB 16GB 16GB 5Ghz WiFi No Yes Yes Dolby and DTS Play by XBMC Play by XBMC Hardware decoding
Despatch time Around 2014.06.14 Around 2014.06.14 Around 2014.06.25
Originally posted by BalintBanyasz View PostI'm sorry to hear that. Are you sure that your NAND is gone? I've had similar problems with the RK flash tools when WMware USB drivers were installed. Have you tried flashing from another computer (maybe from Linux)?
Thanks again.
Originally posted by tecfan69 View PostSince i have a quad core device i did not play a lot with MK808B. Because of your request i took the device in mask rom mode and re-flashed all that KitKat stuff. Your Kernel works perfect now so far.
Thanks again.
Thanks again.
Originally posted by mo123 View PostEven less than 40% CPU utilization and higher than 4500 Antutu score with wifi turned on?
You're in kernel dev, right? Did you hear about a mk809iii kernel with ap6210 wifi booting ubuntu 14.04? I compiled Alok sources and changed gpio but get it not to power on. Would be glad if you can help.
Originally posted by tecfan69 View PostNever test wifi because i use asix. Just gave a feedback in regard to installation.
But mostly concentrating on RK3188 now and RK3288(in a couple of weeks).
Originally posted by totor54 View Postthank you for your help. I just place an order. the Tronsmart Vega S89-S802-H H Amlogic $ 120. existe'il another way to put the mk808b in flash mode. without trombone. thank you to all
or http://promotion.geekbuying.com/prom...ini_pc_release and it's cheaper than what you paid.
MK808B - You can enter Mask ROM flash mode my short-circuiting the pins on the nand chip, look for youtube videos for instructions.
Originally posted by mo123 View PostIf you can give detailed info and source, I can have a look.
As mentioned i build not a KitKat but ubuntu kernel. At line 76 i tried GPIO3_A0 and
RK30_PIN3_PD0 without success. dmesg said failure power on wifi.
What i do not understand is how to get the values that triggers these pins.
I tried a 802IV ap6210 kernel compiled from other sources but this one uses firmware and modules of picuntu 4.5 and bin files located in /system/etc/firmware. There's also rkwifi.ko that has to be loaded. This kernel seems to work. iwconfig gives wlan(0) but all values are not set. Besides wifi powered off at the end of dmesg.
Originally posted by mo123 View PostWhy not buy this device http://ugoos.net/ugoos-ut3-16gb-rk3288 much faster and better graphics chip.
I managed to put it. found RKAndroid
there forever. IDB download error filled
Flash a KitKat ROM again with RKFlashTool v1.7, a single update.img.
Then use Finless ROM Flash Tool v1.37, you are using version v1.35
- load KitKat parameter file, then erase IDB
- now you can flash Jellybean ROM parts again with Finless ROM Flash Tool v1.37
Here is a parameter file for KitKat - http://www.mediafire.com/view/w877rn.../parameter.txt
Originally posted by mo123 View PostIf you go from a KitKat ROM then flash a Jellybean ROM you will brick your device.
There are currently 2016 users online. 0 members and 2016 guests.
