I would like to help in having a stable kernel for mtk chipsets...
MK808B KitKat kernel [Working WiFi & BT]
MK808B MTK kernel
Originally posted by aldinezi View PostWould it help you if i dump you a dmesg from working kitkat kernel and mtk modules...?
Originally posted by tfpereira View PostI encountered that error too, for some reason that variable is not defined in that scope. In my case (MK809II ) I just replaced that variable for the actual pin number, which in this board's case is "RK30_PIN3_PD2" (or so I think from GPIO Dumps I made).
I was able to succesfuly compile the module, and the drivers DO load, my only problem is that even though the drivers are loaded, the interface wlan0 does not appear.
Anyway, thanks for the interest in this problem.
I've set the config according to a documentation I've found in Rockchip's SDK:
RKXX_Android4.4-SDK_WiFi BT 配置说明V1.0
And here's the kernel (MT5931 WiFi, MT6622 BT):
kernel_mk808_mtk_kk.img
Originally posted by BalintBanyasz View PostYes, that would be helpful. Please test my kernel and report back.
I've managed to compile an MTK kernel. I had to set RK30SDK_WIFI_GPIO_WIFI_INT_B and remove an 'inline' tag from gl_kal.h (MTK driver folder).
I use Shomari's kitkat rom, and unfortunately I can't boot with this kernel. It just shows two penguins in upper left corner of the screen.
It doesn't boot with Uhost ROM too..
Reverted stock kernel, and it boots.Last edited by aldinezi; 23 November 2014, 13:58.
no boot with Shomari's kitkat rom
i've tried this kernels :
kernel_mk808b_kk_720p.img
kernel_mk808b_kk_rtl8192cu.img
kernel_mk808b_kk_rtl8192cu_edid_sound_vsync.img
kernel_mk808b_mtk_kk.img
using Shomari's kitkat rom and show two penguins in upper left corner, with kernel from Shomari it boots.
MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
Originally posted by aldinezi View PostOk, I can try, can you just give me another link. Because the one in first post doesn't work.
Any efforts in making bootable kernel?
Your kernel is still my only hope..
Thanks for your help.
Originally posted by gurzo82 View PostI have installed Dumonde Rom and this kernel and everything is perfect..only one problem, how can i increase de partition for app to 4gb? Is it easy?Anyone could help me?Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by givecredit View PostWow! I installed this on my 808 (non b) version. Bought a $5 usb to ethernet adaptor and Domondes rom works perfectly with the kernal dated Oct 2014 posted here a few posts back.
Thanks a million. This has brought a whole new lease of life to my MK808.
I have an MK808B (original, with RK903 chip set, purchased from Geekbuying in June 2013). As my on board WIFI chip is fried (OTG cable took a dip in fish tank under TV). I have purchased an external chip which is a Realtek RTL8188CU. I have this working fine with Fineless ROM 1.7 using a driver from http://www.armtvtech.com/armtvtechfo...ile.php?id=180 However I would like a more up to date ROM. I see that BalintBanyasz has a kernel for KitKat that should work with this WiFi chip. However I have tried the following roms...
- Dumonde's MK808 ROM (rooted) --> two penguins
Downloaded from https://mega.co.nz/#!VdljCDxY!94jrZu...JExYKt8bitPSqw as link in OP no longer works
- mShomari's Kit Kat 4.4.2 RK3066 --> runs but screen keeps flashing with and android in top left hand corner of screen and can’t do anything
- Smallart Uhost2 KitKat (U2.442.000.11.140327) --> can’t try as links in OP no longer working.
I have tried loading Dumonde's and mShomari's both are single img firmware with AndroidTool v2.1 both appear to include the new bootloader in the image.
Other users such as totor54 rk903 and Lude have had the same problems loading KitKat . Others such as Lokotito have been able to boot Smallart ROM but unfortunately the link in the OP no longer works so I can’t try it.
With any Android ROM's for 4.2 or 4.1 I have never had a problem flashing them and running them. I have no problem going back to a jellybean ROM they always boot. Any ideas what I should try to get KitKat running?
There are currently 2081 users online. 0 members and 2081 guests.
