Now i will re-flash it with this rom 900supersport 1.1 CWM Cube U30GT H newer version i hope that will fix the issue by the way thank you @deanfarnaby But i dont have much hope
unfortunatly nothing worked on my cube and the intresting thing is i put away my cube before i sleep and battery was about %40 when i wake up in the morning it was off and didnt come on it was dead when i put the charger it turned on.While its charging screen goes crazy you touch some where it goes another way )
So cube bad experience :/
Sounds like you have a bad battery if it dies around 40% - Mine first Cube did this at 30% ish.
The crazy touch screen is related to the charger not the tablet - The charger is producing a voltage accross the tablet - like an electro magnetic field. If you touch the metal strip around the outside of the tablet while plugged in the touch screen will work ok. I reccomend a new charger. Although I bought one from a recomended seller , supposed to be good quality chargers and it still has the problem. Many people have reported a new charger fixes this issue.
Did you get any further with the market problem?
Market problem still continues,i cant download any thing.Whats worng i dont get it.
And the battery will it be fixed after charge?
