NEW - 900 Supersport rooted ROM for Cube U30GTH
    Re: NEW - 900 Supersport rooted ROM for Cube U30GTH
    I'm hoping to be pulishing updated roms for the cube mini and the h over the weekend, the h will be based on 1.7.
    At the moment I've broken the usb on my h, as such I will play it safe initially and stay with a full ROM kit. In any case 1.7 will have a kernel update so will require a full flash.
    900Supersport
    freaktab developer
      Thanks and I'd forgotten about your USB problems, sorry.
      Sent from my U30GT-H using Tapatalk 2
        No problem, really enjoying the mini.
        900Supersport
        freaktab developer
          need helps..
          Hello... and greetings from Indonesia..
          I have succesfull install your ROM... and I think is the best rooted ROM for cube u30gt h that available right know.. and many thanks to you...
          I can't wait for you to develop new ROM based on fw 1.7..
          But I have a question to you :
          After I installed your ROM, I can't access Google play anymore.. I try connect with WiFi or via 3g modems still can't access Google play.. my Google account is active and I can receive push email from my Google account... what I must to do?
          I.m sorry if my English and my grammar is bad.. I wish u can understand it..
          Thanks...
            Go to settings and storage and check the nand is mounted
            Sent from my LT26i using Tapatalk 2
              Geeksindrome
              Thanks for the compliment, I've had no issues with google play myself button have memories of reading of some issues. I think they may have been cured by clearing the cache on google play. I'd give that a try, you may need to reboot and clear the cache again.
              Another thing you could try is removing your google account from settings, clear the cache reboot then try google play, you should. Be prompted for your account.
              Good luck with this, let us know how your get on.
              900Supersport
              freaktab developer
                Geeksindrome
                Also try clearing the data for Google Services Framework as this worked when I had similar issues on my htc hd2 phone.
                  Thanks everyone...
                  Finally i can access my google play store with my own account :
                  1. ClEar data And cache google play
                  2. Clear data n cache google Service framework
                  3. Removing Account and login Again with my acoount
                  And its work..
                  edit :
                  i found another problem, i cant wake up my tablet when i m not activated it for more 5-6 hours.. when i push the power button there is nothing happen.. just blank display, it like im running out the battery, but im absolutely sure my batterry was full.. is that condition called as deep sleep?? is there any solution to fix this problem? so far to fix this problem and i can wake up again the tablet it just plug in thr charger, and then the tablet is wake up again.... is there any other solution?? thanks...
                    Hello, first of all thank you for your excellent ROM; it is the first one since I bought my Cube, having 2 GB of RAM instead of 1 it's very useful for me as I tend to have many programs opened and change between them.
                    I have some question, do not misunderstand me, I am aware that you are having some hardware issues, but there is any chance to get an update for your ROM based on official 1.07 version?
                    I want to try 1.07 to see if it solves some problems I am having with SD card and it would be better if it were with one of your ROMs, otherwise I will try with the official one and see what happens, keeping a nandroid backup to restore. If I install the official ROM would I keep CWM recovery? And what about the position sizes?
                    As I said before, thank you for your work.
                      Flashing the stock firmware will take you to a full stock cube, you will have no clockwork and just the stock app space. As the stock tom is not rooted I doubt you would have any good backup and recovery options.
                      My 1.1 rom based on cubes 1.7 image will be available soon.
                      900Supersport
                      freaktab developer
                        Thank you, I will wait then.
                          SD card problem still exist
                          900Supersport and Bob,
                          Thanks a lot for this nice ROM. I start using it this morning (eventhough through "black out stage and need unbricking" LOL). But finally I got your ROM running smooth in my Cube. Stable wifi, no buffering problem in Youtube. Backup with ClockWork also work fine. Just one last problem.
                          My cube wont detect ext4 SD card, and when I format it to either NTFS or FAT32, the SD caed will be detected and running well for sometime, about 5 minute, and then starting to cause sporadic hangs here and there. And when I check with ES explorer, the external SD card is missing, and seems that it unmounted itself.
                          Working all day long to fix this with no luck. Any help would be really apreciated...
                          Javen
                            Ntfs has been quite robust for me though can be reformatted by cwm if you leave it in during flash. I'm surprised you are having issues with ntfs, could be hardware related as the socket for the sdcard seems low quality.
                            900Supersport
                            freaktab developer
                              1.07 fixes the hang issue
                                Just posted a 1.1 ROM for the gt h base do. Cubes 1.7 firmware.
                                900Supersport
                                freaktab developer
