NEW - 900 Supersport rooted ROM for Cube U30GTH
Re: 900 Supersport rooted ROM for Cube U30GTH
Is the change log for this rom is as stated in OP? No other optimisation/tweaks?
I don't follow bob's finless roms for other devices so I don't know if there are tweaks that is included on all finless roms that is suppose to be understood.
Thanks.
Change log on first post is correct. The ROM is my work but relies on bobs cwm recovery, so any credit for the misc.img and recovery.img goes to him.
Currently the ROM gives you cwm, full ext4, root, de-bloat, English and two gigs app space.
I'm currently testing integration of market fixes and a few other bits and pieces and will be releasing a new version of the ROM soon, with further refinements to follow.
If you have a wish list then share and some may be included in future ROMs.900Supersport
freaktab developer
Originally posted by tablighs View PostThat is usually a problem with the charger.. quite a number people had that issue and they change to a more quality charger.
Thanks!
/edit:
Originally posted by 900supersport View PostIf you have a wish list then share and some may be included in future ROMs.
Also: could you include Google Calendar & Talk in future releases? I was able to install the .apks i pulled from my Galaxy Nexus running CM10 and it works perfect.
Thank you & keep up the good work
I'll start compiling a wish list :-)
I don't think it's possible to update the kernel be cwm on rk3066. If I release an update based on the same kernel I'll look at a cwm release as well.900Supersport
freaktab developer
RK ROMs are a little different. Once you pull kernel out of recovery and boot and make it stand alone, CWM cannot update kernel.img. So while ROMs can be made as ZIPs and update that way, if the new ROM has a new kernel, it cant update the kernel.
Youtube
Hi. Was anyone able to resolve the Youtube stop/start buffering issue yet? I'd love to know how you did it. It's the one thing that drives me crazy w/any of the JellyBean firmware's I've tried. It's got to be inherent to the app itself as it doesn't cache buffer inside Firefox or Browser's plug in..
BTW Supersport... Love your rooted ROM.. very nice indeed.
Re: NEW - 900 Supersport rooted ROM for Cube U30GTH
YouTube HD mode buffer problem has been there since JB was released from cube,unselect it and it should buffer fine. No fix so far unless you use ics then the fix is to revert to previous youtube app version which if used on JB will crash the app.
The fix is to use a old version of Youtube. I posted a link to it in the Yaundao forum. I will see if I can find it later.
I don't think that version works with JB.900Supersport
freaktab developer
Hi super sport
I have been using your ROM for a while now and was trying to get my gallery to sync with Google+ so flashed a gapps.zip with cwm which didn't do anything anyway since doing it my tab is going slow. I was wondering can I just reflash your ROM and keep my settings also when is the eta foe the new version
Homeless, is that the stock ROM you have on that? Or did you flash something else?
If that is that way out of the box, you may have a bad wifi hardware?
There are currently 2450 users online. 1 members and 2449 guests.
