Welcome to the 2nd 3288 ROM I have ever made. Still learning this new box.
This ROM was made from the latest release from Beelink. 110K4109_1016.
This ROM will work on the following and has been tested by me:
Beelink R89
Tronsmart R28
HPH TV Box with 16GB.
Please don't ask about other devices as I don't have them and cannot test. But 3288 ROMs seem to be pretty generic.
_________________________________________
Features and release notes for my 1.2 ROM:
1) Stock ROM was only 2 gigs of APP space.
I now supply you with 3 parameter files to choose from:
2gig - the default if you do nothing
4gig
8gig
If you guys want more let me know.
2) Debloated of junk APPs.
This includes the XBMC that came with 110K4, etc.
Why? Because if I don't do this and you do a factory reset, that XBMC always gets installed on first boot!
Removing it allows you to install whatever XBMC you want.
I do supply the original XBMC that came with this ROM in the Removed_apps folder so you can install it if you want.
3) All Google Apps and Google framework, Play Store, etc are updated to the latest as of this date.
Not sure why Beelink doesn’t update?
4) As always, I added full init.d support! If you do not know what that is... ignore it.
For geeks that want to use it. It is there!
5) Build.prop edit to open up the Google Play store to APPs that normally say "not compatible".
I am spoofing a Samsung device that will show almost any APP as compatible.
Your device will show up in google play as Samsung device not a R89 or R29! Understand this please.
I also left the original build.prop in the ROM called build.orig.
If you want to go back, just use ES FIle Explorer or a root file explorer and rename build.prop to build.old
Then rename build.orig to build.prop.
Go into settings, apps, all and go into the Google Play app. Clear the cache and data.
Reboot! You should be back to showing up as a R89.
6) I added a reboot APP that will allow optional reboot options like reboot to bootloader (flash mode).
7) Other tweaks I do to add performance like buffer sizes, etc.
Yes I still tweaked the TCPIP buffers!
Other tweaks which are my trade secret
8) I did a tiny bit of theming to the launcher3 wallpaper.
9) I removed kernel from boot.img.
This will allow using different kernels later as the Dev's here make them.
___________________________________________
OK here is the download.
DOWNLOAD THIS AND UNZIP IT!
READ the README.TXT in the ZIP for instructions on how to flash this ROM!
ROM -> R28/R89 HPH 3288 TV Box - Finless 1.2 ROM (414 megs)
Enjoy,
