NEW - R28/R89/HPH Finless 1.2 ROM
    Thanks no_spam_for_me. Before I reflashed back to stock I put on SPMC and the box has not crashed yet, yay (It would crash under every version of gotham or Helix I tried once I tried to ff or rewind or it would just randomly crash for no reason). any way no more RK3288 boxes for me...
    Cheers
    Mark
      Nice ROM once again, but is there anyway easily to change screen orientation? I tried to edit build.prob but without success.
      -AP-
        Hi. Big thanks for the great ROM and your time to make these boxes even better.
        Thus I have one problem, maybe someone heard how to fix it. Problem is with wireless keyboards, when I type something in android some of the keys got stucked liiiikeeeeeeeee thisssssssss, tried both keyboards and for both are the same issues. The keyboards are fine, tested them on pc. Device is Ubox R89.
          At Tronsmart/UBOX/Beeling try the OTG port....
          RK3288 Devices
          - Overview BOX (LINK !)
            Please BOB add HDMI CEC to rom !
              HDMI CEC support has only been added in November by Rockchip.
                Hi.
                The Ubox then is not recognizing the keyboard/remote controller. Is there some procedure to initialize it?
                  Originally posted by kpcz View Post
                  Hi.
                  You have to unselect the "Connect to PC" at settings (I think it is at [USB])...
                  RK3288 Devices
                    oh, okay, didnt try that. Thanks. Will try and report
                      Thank you very much, now it works perfectly
                        Originally posted by amclean123 View Post
                        Bob, Great ROM! Thank you!
                        I noticed that Google Play is missing apps for this ROM. Try installing the The Weather Channel, iHeart Radio, or MLB apps and you'll see that Google Play Store says my device is not compatible.
                        Also the following application are not compatible with this rom
                        Google keep
                        Fifa 2015
                        Need for speed.
                        Can we do something in order these app/games to be compatible?
                          IR Remote
                          Firstly, thank you for your work.
                          My remote seems not work properly:
                          the button (-) turns the box in standby mode,
                          all the others have no effect
                          The OTG port does not recognize my keyboard (logitech k400r) as the stock rom does (connect to PC unchecked)
                          with stock rom
                          Regards.
                            Originally posted by outsize View Post
                            My remote seems not working properly:
                            [ATTACH=CONFIG]9087[/ATTACH]
                            Since installing finless 1.2 I can't get the stock remote to work whatsoever.
                            Also, anyone know if its possible to remove the startup animation? It's seizure inducing.
                              CifsManager
                              Hi everyone.
                              I tried to mount my NAS with using CifsManager.
                              (mount point is /mnt/cifs/XXXX )
                              But I couldn't and got error message "mount : Permission denied".
                              Did anyone succeed ?
                                Originally posted by maru View Post
                                Hi everyone.
                                Then you are not rooted or your network doesn't give the correct permission to access the files.
