NEW - R28/R89/HPH Finless 1.2 ROM
Hi Bob, very nice and clean rom. It is good that you have not included the kernel in the boot.img, because your rom can be used on any rk3288 with the proper kernel.img and resource.img. I use your rom on ENY EKB328, but with eny stock kernel and resource.
Please do not include the kernel in the recovery.img. If I flash the recovery.img that comes with your rom the ir remote control does not work in recovery mode.
Regarding the launcher, there is one button on the light home launcher that doesn't do anything. I think it was meant to open file explorer.
I was using Oma cRom v1.1 from crewrktablets (RK3288: Rockchip Box Bulid). You can find there all the kernels for different boxes.
I am now switching to your romMany thanks!
Hope to see a new version soon !
All stuff I will look into
Originally posted by maxxxy View Postsorry but in the folder there are 6 finless rom .img files
Which one should I use?RK3288 Devices
- Overview BOX (LINK !)
Some Lighthome Troubles
tried this image today on my UBOX R89 and it works great but i have found some little problems. After i had installed Asphalt 8 Airborne i can't run it with Lighthome Launcher. I can only run from play store or from Launcher 3. Also after i upgraded XBMC/KODI to the latest nightly build i can't run it with the big XBMC Button on the top. Is is possible to fix this problems?
kindly regards
renmet
I've installed fineless on my UBOX R89, thanks Bob!
ir remote work great!
I've find 3 problem:
- i can't download app from play store using Lan... mah... he ask me to use wifi way
- xbmc kodi not work good, video are jerky, problem on 1080p video (i've tried a lot of films like Madagascar)
- spmc work no perfect but good
- stock player work so and so
what player can i use to see film smooth and good? mx player? dice player?
i'm stressed because R89 have great hardware but not work good to decode hd films..... mxiii is little better...
help me!
inviato tramite collegamento psichico
How to install apps from Network using play store
Originally posted by crazymark View PostI've installed fineless on my UBOX R89, thanks Bob!
8Gb
kindly regards
renmet
Can i use in my UBOX R89 the 6Gb file to have that app space?
R: NEW - R28/R89/HPH Finless 1.2 ROM
Originally posted by drolevar View PostHi!
Is there any way to make internal SD to use ext4 instead of vfat? 4GB file size limit is not a good thing even though the total size is only 16GB.
Originally posted by gaetanolip View PostWhat? It is the first time I hear such a thing. Internal sd in vfat? Are you sure? Any other boxes have this vfat?
Code:/dev/fuse /mnt/shell/emulated fuse rw,nosuid,nodev,relatime,user_id=1023,group_id=1023,default_permissions,allow_other 0 0 /dev/block/vold/179:14 /mnt/internal_sd vfat rw,dirsync,nosuid,nodev,noexec,relatime,uid=1000,gid=1015,fmask=0002,dmask=0002,allow_utime=0020,codepage=437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
There are currently 2283 users online. 1 members and 2282 guests.
