NEW - R28/R89/HPH Finless 1.2 ROM
    I don't know if you will find a solution to fix the problem with the changed remote...
    But if you want to use a state-of-the-art rom, you should have a look at http://freaktab.com/forum/tv-player-...-tronsmart-r28 (2.0.7 or 2.0.8) and use a wireless (air)mouse/keyboard...
    (BTW it uses the whole eMMC/Nand at one partition)
    RK3288 Devices
    - Overview BOX (LINK !)
      I am a bit outdated about this... but... do U mean that with latest wasser ROM even the "new" (second one) Tronsmart remote will stop working???
        Yes it won't work.
          even the newer one? So the internal IR receiver would be useless... right?
            With all the effort it took to make them send the newer version of the remote..
            Is there any way to get those code(s) from Tronsmart?
              Is there any possibility of updating this firmware to 111k4110_1219 ? Finless
                hello i have now got my r28.
                so before i take this i have a fewvquestion.
                does this havevoption to havee all storafe as install apps and tweak it so game data and app data is on external sd. or is thisvposible to make so i have full 16gb to install apps and games and the game and app data folder on external sd and also al obb files there to. i think many would like that if it isnt there but if it is then all is perfect.
                  If you look at the description on post 1 it says.
                  2gig - the default if you do nothing
                  4gig
                  8gig
                  So there are 3 choices but not one for all.
                  This is an old ROM now though, so you will be better off looking at others from Wasser/Mo123 etc, where you will tend to find unified storage that lets you use all the space available as one partition.
                    Ok i look into that. I more meant a 0gb preset and all data is on ext SD card.
                      Please help me! If i have pro version, with 2 gb ram and 8 gb storage, what parameter can i use? 2 gb, 4 gb or 8 gb? I am not shure. Sorry for my bad english, i,m romanian. Thanks for help.
                      Trimis de pe al meu Orange Gova folosind Tapatalk
                        2GB or 4GB
                        8GB only for 16GB ROM devices as about 2GB is used for Android, then it's going to be 10GB which is more than the storage on a 8 GB device.
                          Thank, i will try with 4 gb parameter. Respect.
                            i flash the rom with 4 gb parrameter. Everything is fine, but youtube is playing in 720P. Any advice, please?
                            And, of course, the remote control is not working. The(-) button put the player in sleep, the others not work at all.
                            How i can fix the remote control problem? Youtube crash if i try to move forward (seek)
                            Trimis de pe al meu Nexus 10 folosind Tapatalk
                              Hello again. Can anyone give me the original remote.conf at Tronsmart Orion R28 pro? I flash the R28/R89/HPH Finless ROM and the original remote control not work. Maybe if i replace the remote.conf with the original one i solve problem. Thank you.
                                Please flash wasser 3.0.3 firmware.
