Hi Bob, love your work and have had great success with your roms in the past with other boxes, A98, minix x7, x8s however I just got the orion rk28 and I am sure it has a fault, it keeps crashing and wifi just will not work, also ethernet works but takes a while, I flashed your rom hoping it would fix the issues but no luck, done factory resets as well, I need to go back to stock rom so I can send this back but cant see instructions. I downloaded the stock img and used the flashtool in upgrade firmware tab but it still was your rom when I booted it up, is there a stock rom in zip format I can flash rather than an img to over write yours. Any help will be great!
PS. my first post ever
