[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by codesnake View PostYou don't see even startup logo?
it been fixed wipe dalavik and cache. and reflashed
CPU temp display not working either sleep / wake working very quick sleep and wakes up instant is this due to partial wakeup lock?Bugs are Sons of Glitches!
JustMe
Originally posted by JustMe View PostGet the logo amogic then straight to blank screen " No Signal".
Originally posted by codesnake View PostThat's possibly because of different display resolutions used by bootloader and OpenELEC. OpenELEC currently uses the bootloader and recovery from Stane's Android firmware. So until I'll build my own bootloader, there may be problems...
testing now the long sleep period see if it wakes upBugs are Sons of Glitches!
JustMe
How do you see the temperature display, if you said in previous sentence that you see "No Signal" ?
Originally posted by codesnake View PostThe system is put into full suspend (not early suspend) state.
How do you see the temperature display, if you said in previous sentence that you see "No Signal" ?Bugs are Sons of Glitches!
JustMe
Ok have fix for the screen no signal will upload in few hours time thanks to code snake and stane for the missing puzzles and functions missing prior.Bugs are Sons of Glitches!
JustMe
Outstanding work, sir:
- experienced the same initial boot-up issue as others, but it's up and running smoothly. Still don't see an OpenElec splash screen. only the M8 logo, but who cares when it boots up so fast...
- very fast interface; menu items and links spring up smartly. Faster than AmLinux (second build) and OpenElec beta; as snappy as Armada Pure Linux.
- superb power management: remote shuts down and brings things back almost instantly. Bravo..
- great video playback on 1080p material: beautifully smooth, with crisp images; able to jump between video chapters with minimal or no buffering;
- Spdif output enabled out-of-the-box. Thank you! Slight audio delay on receiver end when using both HDMI and optical
- have had one freeze after backing out of an add-on. An isolated case.
Much more to test, just wanted to convey this:
Codesnake you have donne this box wonders, OE is awsome thank you.
I have one thing I that isn't working
- 5ghz WiFi band is not being populated
Also just a question, will native bluetooth on the box work in future builds of OE? Not that it's a big deal.. I'm just curious...
Thanks for all your work
Re: OpenELEC for Amlogic-based TV boxes
Originally posted by pigbait View PostCodesnake you have donne this box wonders, OE is awsome thank you.
There are currently 2101 users online. 0 members and 2101 guests.
