[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Here's a new build for M8 that has the following changes:- forces 720p video mode at startup that should fix the no splash / no signal issue.
- enables 5GHz band for built-in Wi-Fi.
Download: https://googledrive.com/host/0B4FNwq...el-99a1eba.zipLast edited by codesnake; 27 October 2014, 21:24.
When I use my gbox running OpenELEC for live TV and the live channel doesn't load up and just continuously
spins and says working. I have manually stop it with the remote and it freezes. The only way to get out is to turn the power off with the remote. When the live TV channel is frozen on the M8 running this build the power button will not work at all and there is no way to turn the box off besides pulling the power plug out.
On my 46 inch tv I get no M8 splash logo and no OpenELEC logo, just bolack screen then gotham, then xbmc and that with video settings both 1280 x 720p or 1920x 1080p . On my 26inch TV I get M8 logo, no OpenELEC, but black screen, gotham then xbmc.
Also box goes right into xbmc when powered back on, no boot up.
Originally posted by codesnake View PostHere's a new build that has the following changes:- forces 720p video mode at startup that should fix the no splash / no signal issue.
Download: https://googledrive.com/host/0B4FNwq...el-99a1eba.zipProud xbmp>xbmc>kodi user since early days of 1st gen xbox
XBMC on :
Tronsmart S89 Quad Core - Openelec
Atv1 + Crystall HD - Crystalbuntu
Raspberry Pi - Openelec
Xios DS - Linux the-hydra
1st gen xbox, JB Atv2, Ouya, ...
Originally posted by MetalKettle View PostYour live tv issue could be to do with the version of librtmp included in the openelec build? I'm not sure what version codesnake has in his build.
Its no big deal when it freeze on the gbox because I can just turn the box off with the remote and not have to worry about losing my settings when I power back on since Codesnake fixed that issue.
But M8 will not power off at all with the remote when it freezes.
Originally posted by al8782 View PostI'm not familiar with that, even though I do have an idea what rtmp is only because I've seen it in some live channel sections.
There are currently 2835 users online. 0 members and 2835 guests.
