[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by codesnake View PostThat's because you have downloaded a wrong firmware. You downloaded for G18 (MX2), but you need for M8 (K200). Read carefully before downloading, because you can brick your box.
I'll try again with the good one.
Thanks for your reply.
Edit :
- flash in progress ... automatically with extracted files on SDCard.
- reboot
- Open Elec Splashscreen
- XBMC Splash screen
- XBMC/Openelec Menu.
I test all functions right now, and back to you with a feedback ...
Thanks !
Thanks code snake
Have the m8 802 installed as per instructions looks great and runs even better. Just one question can I or how do I install ultimate xbmc ux (donated version)on this rom. If it can be done I would appreciate any advice. I am new to the Linux stuff and any advice on how to install this on this rom would be appreciated. I was on finless 1.8 before but this one is slick quick and very nice. Again any dvice on how to install UX would be appreciated. FANTASTIC ROM
So ... my feedback.
Firstly, the IR remote is not ok. At all.
Concerning the Finless ROM, I had to replace the file remote.conf to have it working.
So I plugged a USB keyboard, and set the basic settings :
- LAN Eth and Wifi are OK, perhaps an instability with the wifi, because I had a lot of buffer errors, even on small files.
- Language and keyboard mapping through the Openlec Menu (ok with french AZERTY)
- SMB file sharing on my NAS.
- Video playback OK, sound also.
- AirPlay ok (audio only, even if the icon with video appears on iOS devices ... in this case in didn't work at all, but ok for Spotify for exemple).
- SSH ok also.
- Menus are fast. Very very fast comparing the Android XBMC version.
- Boot extremly quick also ...
Seems to be really really good, except for 3 things.
- I didn't find how to configure the remote of the CSM8.
- Bluetooth is not reconized (not a problem for me).
- Video playback is crappy, a lot of blocks appears, I can see clearly the artefacs of compression.
I have recovered the poor quality of the XBMC ROMstock playback which have been really really improved when I flashed the Finless ROM and run the 13.2 XBMC downloaded from XBMC website.
But by the way I should admit that I've tested ROMstock with bad videoplayback on a device (the one I've installed OpenElec), and test Finless wich was ok with video on another.
Perhpas my problem of creepy video is an hardware problem, so I'll try to flash this CSM8 with a Finless ROM to check if playback will be improved.
I also have got 2 others totally unboxed CSM8 to do some tests, by flashing Openelec and see if the poor quality will be present on these device too, or not. :-)
As it runs on CSM8, I assume it should also work on Tronsmart S89 (the rounded box) ... perhaps with the same IR remote problem.
Seems to be really really good, except for 2 things.
Originally posted by bajann View Postu don't have problem with csm8 ?when I install finless ROM all was OK but when I restart box to factory I have strange problem when I power of a device unplug power and push power back csm8 lose all install apps all settings all stufs like wipe cash and factory,I think maybe they put something in ROM generetic and when box lose power automatic wipe all ,u have openelec for s82 on RU forum all works but I don't know how to center to fit skreen looks like 100% I need 92%
To be honnest, I've not returned to ROMStock from Finless ... so, no, I've not this problem. :-/
Sorry.
Concerning Openelec, you say you find another ROM on russians forums/sites where all is working (including remote ?) ? Is it right ? If yes, have you an URL to test that ?
But I don't understand your problem with your screen.
Do you have a CRT TV (cathodic TV) and not a LCD/Plasma, and then you want to reduce the interface size to fit your screen ? Have I well understood ?
Originally posted by baal77 View PostAre you saying that, since you've installed Finless, and back to ROMstock, you can't keep app and settings if you reboot the box (or unplug) ?
Sorry.
Originally posted by bajann View PostI have LCD TV I will post tomorrow some photo u will see.like in android settings u have that option to set ,on openelec u don't have that ,my problem with csm8 when I unplug power adapter device shutdown but when I plug power in I lose all data all my set I need again to writes my mail all stufs gone like on factory reset .sry my bad eng,u have URL on this forum that openelec is for s82 s89 tronsmart don't work your remote
Development builds: OpenELEC for M8 with XBMC 13.2 i get no audio
Development builds:
my problem is no audio after install tried optical ,3.5 with rca
tried enabling hdmi with ac when i go into system setting i can scroll up and down but menu
freezes from internet tab through audio vidio tabs lock up has anyone installed it on Armada Mach m8 box with audio working if you could explain how you installed it i had no audio from first boot or 2nd or 3rd 4,5 i am not seeing anyone else having a audio problem only me works fine just no audio like to find my cause of locked menu tabs lack audio my mouse works fine
Originally posted by MetalKettle View PostCopy that line to a notepad file calling it autostart.sh putting in the correct path and file name.
A good path for the remote.conf would be /storage/.config/ as its browsable via windows. So copy the remote.conf there
Copy autostart.sh to the path /storage/.config/
Reboot.
This is in my autostart.sh:
Code:amremote_config /storage/.config/remote.conf
Did I miss something maybe?
...RK3288 Devices
- Overview BOX (LINK !)
See here:
There are currently 3417 users online. 1 members and 3416 guests.
