BTW. Anyone have erratic movement with the spinning color bars visualizations?
[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Thanks very much codesnake ..success installing on my M8N pcb no. M9&M8 V1.0 2104/07/07 with black round remote ...very quick installation...this box will never be the same again..need to test some more..give feedback tomorrow ...one question , anybody here know how to copy my .xbmc file on android from here is it compatible ?saves me from setting up again one by one if its possible..thank you again.
Originally posted by Bogart7777 View PostI am trying to do a backup on my sd card. Code snakes rom show the sd drive in the system but I cannot find its location when I want to do a backup when I browse the folders in xbmc backup. Can anyone help me locate where it is .thanks in advance. Very nice rom
Originally posted by warlock09 View PostThanks very much codesnake ..success installing on my M8N pcb no. M9&M8 V1.0 2104/07/07 with black round remote ...very quick installation...this box will never be the same again..need to test some more..give feedback tomorrow ...one question , anybody here know how to copy my .xbmc file on android from here is it compatible ?saves me from setting up again one by one if its possible..thank you again.
If you do a new box do a backup on it right away which takes 2 seconds since there's nothing on it.
Originally posted by al8782 View PostI noticed that when I shutdown the box it powers off but when I turn it back on with the remote it loads right into xbmc. It doesn't load first to openelec logo then gotham logo but straight into xbmc.
Originally posted by polys View PostEverything working perfectly on my M8N except the remote (as expected). Some of the keys are wrongly mapped (e.g. Volume, context menu etc).
I copied the original remote.conf found in the stock rom to /storage/.config then rebooted but that messed the remote mappings even more. What is the best way for remapping the keys?
This is the remote:
For example, the Menu (context menu) button is swapped with the VOL-
What do I need to change in the following remote.conf (taken from /etc)?
Code:# ZAP-A10 NEC remotefactory_code = 0xfe010001 work_mode = 0 repeat_enable = 1 release_delay = 121 debug_enable = 1 reg_control = 0xfbe40 key_begin 0x4e 2 ;NUM_1 0x0d 3 ;NUM_2 0x0c 4 ;NUM_3 0x4a 5 ;NUM_4 0x09 6 ;NUM_5 0x08 7 ;NUM_6 0x46 8 ;NUM_7 0x05 9 ;NUM_8 0x04 10 ;NUM_9 0x01 11 ;NUM_0 0x42 111 ;DEL 0x51 105 ;LEFT 0x16 103 ;UP 0x50 106 ;RIGHT 0x1a 108 ;DOWN 0x13 28 ;OK 0x10 46 ;MENU 0x41 66 ;MUTE 0x11 78 ;VOL+ 0x4c 74 ;VOL- 0x18 1 ;HOME 0x19 14 ;EXIT 0x40 116 ;POWER key_end
I hate to have to go back to Android just because of the remote.
Originally posted by polys View Post@codesnake Any idea about this. Is it possible that the auto load of remote.conf from /storage/.config doesn't properly work. It definitely does something but even if i copy the same file from /etc/ the remote doesn't work at all.
This is the remote:
Originally posted by codesnake View PostTry to configure the remote manually by running amremote_config /path/to/your/remote.conf from terminal. Also, are you sure you use correct remote.conf?
Code:# ZAP-A10 NEC remotefactory_code = 0xfe010001work_mode = 0 repeat_enable = 1 release_delay = 121 debug_enable = 1 reg_control = 0xfbe40 key_begin 0x4e 2 ;NUM_1 0x0d 3 ;NUM_2 0x0c 4 ;NUM_3 0x4a 5 ;NUM_4 0x09 6 ;NUM_5 0x08 7 ;NUM_6 0x46 8 ;NUM_7 0x05 9 ;NUM_8 0x04 10 ;NUM_9 0x01 11 ;NUM_0 0x42 111 ;DEL 0x51 105 ;LEFT 0x16 103 ;UP 0x50 106 ;RIGHT 0x1a 108 ;DOWN 0x13 28 ;OK 0x10 46 ;MENU 0x41 66 ;MUTE 0x11 78 ;VOL+ 0x4c 74 ;VOL- 0x18 1 ;HOME 0x19 14 ;EXIT 0x40 116 ;POWER key_end
Originally posted by codesnake View PostI have exactly the same remote with my MXQ box. And I can confirm that some buttons doesn't work as intended. Will try to make it work today or tomorrow.As I said in my previous post, the main issue that I noticed is with the volume, home and menu buttons.
From what I noticed, ENY/Acemax now sell the M8/M8N box with this square remote control. Not sure if they will completely discard the roundish one.
There are currently 2558 users online. 0 members and 2558 guests.
