# ZAP-A10 NEC remote factory_code = 0xfe010001 work_mode = 0 repeat_enable = 1 release_delay = 121 debug_enable = 1 reg_control = 0xfbe40 key_begin 0x4e 2 ;NUM_1 0x0d 3 ;NUM_2 0x0c 4 ;NUM_3 0x4a 5 ;NUM_4 0x09 6 ;NUM_5 0x08 7 ;NUM_6 0x46 8 ;NUM_7 0x05 9 ;NUM_8 0x04 10 ;NUM_9 0x01 11 ;NUM_0 0x42 111 ;DEL 0x51 105 ;LEFT 0x16 103 ;UP 0x50 106 ;RIGHT 0x1a 108 ;DOWN 0x13 28 ;OK 0x10 46 ;MENU 0x41 66 ;MUTE 0x11 78 ;VOL+ 0x4c 74 ;VOL- 0x18 1 ;HOME 0x19 14 ;EXIT 0x40 116 ;POWER key_end
[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by polys View Post
Code:
Originally posted by codesnake View PostIt doesn't work after a reboot because the file was modified. It is not exact copy of the /etc/remote.conf. It should look as:
Code:# ZAP-A10 NEC remote factory_code = 0xfe010001 work_mode = 0 repeat_enable = 1 release_delay = 121 debug_enable = 1 reg_control = 0xfbe40 key_begin 0x4e 2 ;NUM_1 0x0d 3 ;NUM_2 0x0c 4 ;NUM_3 0x4a 5 ;NUM_4 0x09 6 ;NUM_5 0x08 7 ;NUM_6 0x46 8 ;NUM_7 0x05 9 ;NUM_8 0x04 10 ;NUM_9 0x01 11 ;NUM_0 0x42 111 ;DEL 0x51 105 ;LEFT 0x16 103 ;UP 0x50 106 ;RIGHT 0x1a 108 ;DOWN 0x13 28 ;OK 0x10 46 ;MENU 0x41 66 ;MUTE 0x11 78 ;VOL+ 0x4c 74 ;VOL- 0x18 1 ;HOME 0x19 14 ;EXIT 0x40 116 ;POWER key_end
If indeed it's a problem with the beginning of the file, what should I change in the following to swap MENU with VOL+ ?
Code:[FONT=Verdana]0x10 46 ;MENU[/FONT] [FONT=Verdana]0x41 66 ;MUTE[/FONT] [FONT=Verdana]0x11 78 ;VOL+[/FONT]
Originally posted by jackmate View Post@codesnake ,
I got ur build in my m8n with square remote ,some keys in remote like volume button doesn't work,what can I do to make it work .
Is there a remote conf file I should use ?
It's not you ... But enough far of your screen, it's not so bad.
It's the same as with Finless or ROMstock in fact, and near my Apple TV 2 quality also.
I had my nose on the screen for these tests, so I was totally obsessed by the artefacts of compression, but once my ass in my coach ... it was the same than ATV2.
This evening I'll try to correctly configure my remote.conf and it will be OK for me.
Originally posted by codesnake View PostEach ROM just use the same hardware decoding provided by the S802 SoC and the kernel, so I don't know how do you see any difference.
I've perfomed the test with two CSM8 yesterday, each flashed with your ROM, Finless 2.0 and StockROM ... and it was strictly the same quality for each.
There are currently 1393 users online. 0 members and 1393 guests.
