[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
    Originally posted by Carccaussa View Post
    Hi, I'm trying to install the latest linked version, from recovery menu it said that it was successful but, I'm stuck in the splash screen with the following error: error in mount_storage: mount_common: Could not mount /dev/data
    Any ideas?
    Thanks in advance
    What box?
      M8 square original
        M8 square original
        Try to wipe data/factory reset from recovery.
          That did it, thanks a lot
            First of all, thank you very much for this to codesnake, this is the fastest, most responsive version of XBMC I've tried, it even played some DTS (in wav container) files that Android was not able to, although it still stutters with 24/96 FLACs, but I think that's another type of issue.
            The main problem that I have right now is the remote. Only directional and Enter keys work, so I'm not able to display the context menu to add media to the libraries or control the media that is playing with its respective keys (ff, play, stop, etc), I'll be reviewing the entries in this thread regarding that configuration to try to solve it. Also tried with an usb trackpad but the right click event doesn't seem to be recognized.
            Using version dev-bb377b3, on M8 square, original remote.
              More help
              You need to move your addons into /storage/.xbmc/addons/ on M8.
              I have looked in file manager under file manager system in xbmc and I cannot find the /storage.xbmc/addons location. How do I find this location? Which program addon should I use to find these directories. I also want to move my xbmc file from my ps to openelec. Thanks in advance.
                have you tried xbmc key map editor? in add ons?
                  Go to SYSTEM - APPEARANCE - FILE LISTS .. and enable "Show hidden files and directories".
                  .xbmc folder with be there in the file manager
                    i want to try this on my mxiii 2g but even codesnake isnt 100% if it will work and i dont want to brick it, i know that people have said it can use the s82 finless roms, but not sure about if it can use this
                      Thanks bud
                        I did now and it worked! Just had to do some manual editing because there are some keys that I don't need like 'Mute' and had to override them, I'm using a harmony remote, some keys are now mapped to useful functions like skip, prev, ff, etc. works great
                        Thanks again
                          MXIII 1gb
                          Could this possibly work with MXIII with 1gb?
                            Thanks for the rom
                            works awesome on the M8 also it works on the T8
                            can u plz map the T8 remote for it to work
                            Thxs to codesnake & stane1983 EXCELLET WORK Guys 👊
                              100% will not work with 1GB version.
                                thanks for prompt reply. Appreciated. Would you be interested in supporting the mxiii 1gb? if yes i can assist in building and testing..
