[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by dave_leeds View PostStill running the stable Gotham release of this ROM on my square M8, rock solid and great performance. Can count the number of crashes I've had on one hand.
Absolutely brilliant, thanks again Codesnake.
That build runs great, but I'm not able to install on my G Box Q for some reason. Builds after that install fine, it's just the gotham build gives blank screen
I bought this box
http://pages.****.com/link/?nav=item...167537&alt=web
Can I install OpenElec on it?
Is it worth it or should i stick with android.
Openelec 5.0.6 M8
My Openelec 5.0.6 build for M8 built from Kerber Openelec (i have not tested it yet, try at own risk !!) https://www.dropbox.com/sh/u962pjgfl...AyEn-wrka?dl=0
Openelec 5.0.6 build from Codesnake Openelec failed to build 2 times, will try again later.
Code:gzip: stdin: not in gzip format tar: Child returned status 1 tar: Error is not recoverable: exiting now make: *** [release] Error 2
How do I fix that?
Hi Codesnake,
i noticed you posted 5.0.6 on we tek forum, will we see it soon here for M8? I understand that you are sponsored by we tek and doing other builds in your free time but will be really pity if you give up on us...
Also will you have time to look at stereoscopic 3d mode and airplay in one of your next builds, both not working on 5.0.3 and had it working smooth on 4.2.1 Gotham?
thanks
Originally posted by Jönke View PostMy Openelec 5.0.6 build for M8 built from Kerber Openelec (i have not tested it yet, try at own risk !!) https://www.dropbox.com/sh/u962pjgfl...AyEn-wrka?dl=0
How do I fix that?
i tested it when i hit shut down it froze and time is not correct time ... try rebooting and nothing had same problem on 505 of openelec mac address doesn't even match box mac hope to see a good working stable version out..........and i didnt have no m8 overlayLast edited by manny729; 21 March 2015, 07:28.
There are currently 3595 users online. 0 members and 3595 guests.
