Thank you..
[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Hi guys I am having issues with updating from 4.2.1 to 5.0.3 on my MX2
I did tried by putting the .tar (file required for updating) in update folder and i got screen flickering and same happened on my 2nd MX2 box as well. I tried by doing a new install from recovery (after installing 1.1.6 and then unzip 3 files and put on the SD card) and it started and then as soon as I installed tv addons wizard and restarted the box, these was no display (screen just went Black). I reinstalled 1.1.6 matricom firmware and then 4.2.1 and everything is back to normal
PS - I have been using openelec for nearly 10 months now and have used all versions from 4.1.2 to 4.2.1 but never experienced such an issue.
Can some one advise how can I fix this issue and update to openelec
Originally posted by sukhbeer View PostHi guys I am having issues with updating from 4.2.1 to 5.0.3 on my MX2
I have heard people not being able tot run anything past 4.2.x on their cloned box.
Originally posted by IMFan View Post
Do you own an original gbox mx2 or a clone?
I dont have the clone one but it is Generic MX2 (G18REF) board as per the picture https://www.dropbox.com/s/ycy5gpytnvfdgmc/MX2.jpg?dl=0
The last version works on my box is - openelec 4.97
I have asked my friend to come over and we will test 5.0.3 on Matricom MX2 and will let you know how I go
Originally posted by sukhbeer;n502683
I dont have the clone one but it is Generic MX2 (G18REF) board as per the picture [urlhttps://www.dropbox.com/s/ycy5gpytnvfdgmc/MX2.jpg?dl=0[/url]
Hi is it possible to install openelec on my M8 box, below is the specs i have. it has the K200 board. the only reason im asking is because the links for the M8 version at the beginning of this thread says M8 2Gb models, is that 2Gb of ram or something else please.
Chipset: Amlogic s802 Quad core Cortex A9r4 2GHz
GPU: Octo-core Mali-450MP 3D GPU
Storage: 8GB NAND Flash
System RAM: 2GB DDR3
Thanks in advance to whoever can answer this question.
There are currently 2961 users online. 1 members and 2960 guests.
