If it was me I'd flash a newer android and then reflash openelec and see what happens.
[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Yep, same cable and TV. I just switched in the new box.
The only thing I can think of is that my first box (the one that works properly) was running Finless 1.7 prior to me flashing codesnake's OpenELEC ROM. The second one was running whatever crappy ROM it came with from China. On that box I can only select 720p.
Could this be the solution? Put Finless 1.7 on and select 1080p in Android before flashing codesnake's ROM?
Originally posted by dave_leeds View PostYep, same cable and TV. I just switched in the new box.
easy enough to do, so worth a try. i flashed from a stock china rom straight to codesnakes openelec but the stock one i had let you pick 720 1080p and 2160p in the menu.
i install openelec M8 on my box https://www.chinavasion.com/china/wh...ternal_Memory/
and it works only remote was not but after install imon-mce add-on i can power on and off with the remote
the rest of the button don't work :-(
have to use hdmi-cec, so all over it works 99%
Originally posted by WhoCare View Posti install openelec M8 on my box https://www.chinavasion.com/china/wh...ternal_Memory/
Originally posted by NewBe View PostRecently installed Openelec 5.0.3 on my Gbox MX2. Time and Date show as Dec 31, 1969.
Have gone into settings and set country and time zone, still showing Dec 1969.
Is there an SSH command to set time and date?
NewBe
[QUOTE=NewBe;295130]Yes I did. Still Dec 31, 1969
Thanks for the suggestion.[/QUOTE]T
Try this. I got this off another thread for someone else before and it worked for them.
This fixed the date issue
Open an SSH Session
Logon with root username & password
Type date -s "yyyy-mm-dd hh:m" (eg. date -s "2014-07-22 17:47")
Press enter
then type hwclock -wu (this will keep the time & date settings following a reboot)
Close the SSH Session
Originally posted by al8782 View Post[QUOTE=NewBe;295130]Yes I did. Still Dec 31, 1969
Open an SSH Session
Press enter
Just set the timezone correctly and open the openelec settings and set pool.ntp.org under timeservers.
then you will get the correct internet time.
Open an SSH Session
Press enter
I am a novice to SSH. I presume the IP address is the one listed in System Information.
Believe I read somewhere that username is root and password is openelec?
really appreciate your help!
There are currently 2522 users online. 0 members and 2522 guests.
