Links http://amlinux.ru/target/m8/
[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
I'm currently running Kerber's 5.0.5 v1 (from target) and apart from the power off button not working correctly (it reboots device) all works fine. CEC powers off the device and I'm using a workaround to power it on since my player's IR remote never worked in any version of openelec.
...and, same here too.
UART shows:
Code:## Booting kernel from Legacy Image at 82000000 ... Image Name: Linux-3.10.61 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 5027835 Bytes = 4.8 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK machid from environment: 0x4e27 EFUSE machid is not set. Using machid 0x4e27 from environment Starting kernel ... [ 0.000000@0] Global timer: MESON TIMER-A (c0ba1140) initialized [ 0.061716@0] Local timer: MESON TIMER-B (c0ba1240) for CPU0 initialized [ 0.181758@1] Local timer: MESON TIMER-D (c0ba1440) for CPU1 initialized
Originally posted by Kiralina View PostI'm currently running Kerber's 5.0.5 v1 (from target) and apart from the power off button not working correctly (it reboots device) all works fine. CEC powers off the device and I'm using a workaround to power it on since my player's IR remote never worked in any version of openelec.
can you explain the difference in v1 and v2?
and is there an english thread that follows these builds specifically.
im currently running 5.0.3 codesnake and i am looking to upgrade.
theres a few issues currently for me, stereoscopic 3D mode results in "No Signal" for me, so i have to watch 3d movies in 2dmode, which is ok but not good for subtitles or kodi navigation.
also 23.97hz give me a no signal(assuming because my TV doesnt support it) but i would still like to use auto refresh rate change so it moves between 60/50/24 hz like 4.97.3 did for me, currently i lock it on 24p mode but that makes the menus choppy looking compared to 60hz
i also made an autostart.sh file to stop the box from shutting down via CEC when i power off my TV, because i cant power the box on via CEC and prefer to use my TV remote for kodi control over the stock m8 remote.
overall tho these builds on this box is pretty solid. very impressed with this device.
For the CEC issue, you can just use a remote activated power socket and it will automatically power on via CEC both the box and the TV.
Originally posted by Kiralina View PostI don't know the difference between v1 and v2, but they both work well, and I didn't try any 3D content. I have video settings on 60hz, but it auto changes to 24 when needed.
unfortunately my TV uses a bluetooth smart kinda remote and theres no IR from what i can tell.
thanks i will give v1 a go and see what happens.
Originally posted by manny729 View PostWill there be a openelec 506 from codesnake..?
Hopefully he gets around to work on the G Box Q. This is a really good device, I have Code's 5.0.5 running on it now and it's works great. But it's still a problem that some people are still getting the M8 overlay on some tvs.
If code or anyone can fix this problem, I got a couple kegs in my garage I would like to donate :-)Last edited by al8782; 22 March 2015, 22:55.
On one of my mx2's with Gotham 13.2 Openelec Version 4.2.1, I keep getting an error message on boot
"[Failed] Failed to start XBMC hacks."
See 'systemctl status xbmc-hacks.service' for details
I've reflashed this twice and all is ok for a week or so, But then it does it again.
Any ideas?
Originally posted by node View PostQuestion answered: v1 is Kodi 14.2
only thing missing now is 4k resolution working, i only get 1080p when selecting 3840x2160
There are currently 4038 users online. 0 members and 4038 guests.
