[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by piperider View Postthere are different mx boxes if the av is next to the hdmi and the Ethernet lights are on the bottom of the Ethernet port then 116 shouldn't be an issue if not you got a junk mx.The only openelec that will work on the others that I found so far is OpenELEC-G18REF_MX2-4.2.1.zip
But as far as installing Matricom's Android firmware 1.1.6, using the method on the link on the previous page you should be able to install it. If not, then there is something wrong with your box, whether it is related to it being a clone or not.
Originally posted by piperider View PostI tried this with my cmx mx2 I figured if I upgraded openelec to the newest version from this one it would work well now my cmx mx2 is screwed I tried everything but it wont boot on its own even with the older version
Personally, I cannot update above 4.2.1 even on my genuine Matricom Gbox MX2 box due to a problem with no video / black screen at boot (related to the HDMI and newer kernel). So if you have a black screen and nothing else (maybe a flicker at boot for a second), then you are like one of us.
Originally posted by al8782 View PostThis installs 4.2.1 and the you can manually update. I update to Devel build ending in 328.
Hi Guys,
new to forum and new to xbmc, so thanks for having me. First question (of many I suppose) . I have the M8 4K TT TV box square with blue triangle on front. I have downloaded openelec 5.03 from start of thread unzipped and copied to a micro sd card ready to try and install, but could someone please confirm that I have correct firmware for my box. Bit nervous being first attempt and don't want to brick it. Also a bit confused by terminology regarding hardware ie (K200) with Amlogic s802. Is that what I have as I can't see any reference to that on packaging. Mine says Cortex A9 Mali 450. Many thanks for any help
gray
Originally posted by inameiname View PostI just wanted to say that even some official, Matricom Gbox MX2 Boxes, with the AV next to the HDMI (mine's labeled 'Mon'), and the Ethernet lights on the bottom of the port, still cannot update to the latest OpenELEC 5.0.3. So not all of the genuine MX2 boxes fully work with the latest OpenELEC either. Mine only works up to 4.2.1 (well, OpenELEC-Amlogic.arm-devel-20141011031349-r19235-g75190c9.tar). I wish this finally got fixed.
So are you saying your installation of OpenELEC 4.2.1 on top of your successfully installed Matricom Android firmware 1.1.6 worked just fine, but not when you tried upgrading 4.2.1 to OpenELEC 5.0.3? If so, what is the problem.
Do you have the black screen at boot issue like more and more of us when trying to update from 4.2.1? If so, the latest dev build for me that works is actually OpenELEC-Amlogic.arm-devel-20141011031349-r19235-g75190c9.tar. Looking at the ending of the build, my latest that works might be newer than yours. If you want a link for it, I posted it here:
http://forums.matricom.net/viewtopic...rt=2280#p31216
As far as I know the Dev build I use is the last build codesnake posted for 4.2.1 gotham 13.2. This build fixes the problem on the Dev build prior where you weren't able to save any skin settings.
I go and check when the 328 dev build was posted.
Originally posted by smilez View PostSo how many different mx2 are there??? This is a hot mess. I thought there were just the gbox n mx2. That were a like. I wanted to buy in bulk n resell.
My G Box's run awesome. The only problem that I see on this openelec build is if you turn the box off and then turn it back on to fast. You will more then likely get stuck on the OpenELEC splash screen. And that only happens if your box gets stuck and you have no choice to use the remote to shut it down. If you have to use the remote to ever shutdown your box, you need to wait 30+ seconds before you turn it back on.
For what I use my box for, having that issue fixed will make my G Box the perfect box.
ok the **** seller replied back, he said it won't take any other firmware. now I'm asking for a refund. now my question is where can i find the original. i wanna run openelec my reason is why is because its easy for my customer to navigate straight to xbmc. mx2 is the only box I've ever touch and with price i can make a little profit. thanks for replies!
what does this file do? I'm not tech savvy at all. code snake had guide me to where I'm at not through this forum which i think i gave him a lot of headaches. but i really thankful for his work n help.
Originally posted by al8782 View PostI've ordered a lot of G Box Mx's and the only black screen problem I had was on two that I can remember. But that was from a faulty box, because the black screen did happen until I used the box for over 30 mins.
Originally posted by al8782 View PostI get no black screen at all. Only people I know that get black screen are panasonic users and maybe some pioneer. I'll find out soon about the pioneer.
And the black screen issue may show itself on Panasonics but it is a universal problem no matter the tv for me. Unlike what some say on here about it being a faulty box, it is absolutely a software issue as any of the versions from my 4.2.1 I use and below work fine, as well as all the Matricom android firmwares. I am also not the only afflicted. Count yourself lucky you do not have this issue. Overall, there is some piece of hardware in our MX2 boxes which differs slightly than yours and other working ones that is causing the problem.
I believe Codesnake was working on a fix for this, an HDMI bug, I believe, but after 5 months, Ikm losing hope. Not that I blame him given the time he puts into everything and everyone here..
Note: I got another official replacement box just last fall so perhaps the differing hardware piece relates to having a newer Matricom Gbox MX2...
Originally posted by smilez View Postso what do u do when it gets stuck?? do u have to do the boot recovery and reinstall everything??
The other variants have the g18ref board. These are the 2.0, 2.2 and 2.2.1 and are in line with the g boxes. You shouldn't have any trouble installing openelec on these but different boards may have different bugs such as HDMI issues etc
There are currently 3467 users online. 1 members and 3466 guests.
