My point was that you explicitly said this was by-design, essentially a feature, not something to be fixed.
If this was implemented intentionally, it sure would be great to remove it.
But in most of my replies, the additional CEC point I attempt to make is ignored and the personal items are drawn attention-to.
So to clarify: I'm very impressed with your build and the time you spend. You're a god among men. Now that we've got that out of the way, I just wonder if I can get the point across how CEC being supported in one mode, when not in another, is an issue -- and Kodi could better do the job of power-save. If there could just be an option in a config file, that would be fine.
I'm not advocating for CEC to turn anything on. I'm advocating for the ability in the Kodi OpenElec AmLogic builds to disable this "by-design" feature.
Like you, many people don't want their Kodi box controlling, or being controlled, by their TV. But more importantly, if only one feature (Power-Save) is supported by the OpenElec build, and Power-Wake is not supported, it really makes no sense to implement only one side. Especially when Kodi already has a very nice user-configurable power-save feature, and the box draws less than 6 watts at idle.
Most importantly, there are many people that prefer their Kodi box stays on at all times.
This is required by people that like to use it as an Airplay/DLNA server, Torrent client, etc. But Kodi will not wake in the Power-Save state of this OpenElec build. Therefore, having CEC automatically power-save my box, without an option to disable, causes problems at many levels.
