[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by MikeD View PostThis release of codesnake isn't meant for S82/S89. Look at this thread:
http://www.FreakTab.com/showthread.php?t=18924
ThanksLast edited by e123enitan; 27 February 2015, 16:46.
This rom also works because it's nearly the same hardware. But it isn't identical. Because M8 had another remote your Tronsmart remote does not work with this rom.
Look at the thread's last pages. There is a link to a 5.0.3 openelec for your device (S82 version). Beelink S82 and Tronsmart S89 are exact the same devices. Your remote will work with that rom.
Originally posted by MikeD View PostThis rom also works because it's nearly the same hardware. But it isn't identical. Because M8 had another remote your Tronsmart remote does not work with this rom.
Cheers!
Originally posted by piperider View Post
Just got this box tempted to try it.
I tried it buy it didnt update using the method on the page just booted as normal.
Using the update option in settings i could choose the sd card and openelec update.
It rebooted and i got the android recovery screen but just got an error message not correct package.
In addition could you help with this
I need to set correct time and date
also how to captured screen shot or where its located and how to access the file
appreciate your kind support.
Cheers!
"burst of freezes" during video playback
After upgrade to v5.0.3 I noticed some "burst of freezes" during video playback on the M8N TV Box. It looks like slow motion video for 2-3 seconds, with random appearance several times during a movie. Otherwise the playback is smooth. Tried to re-flash the image from scratch (zip file), but the problem persists. There was no such freezes on v4.97.3.
I have following settings in video playback section:
"Adjust display refresh rate to match video" = "Always"
"Sync playback to display" = Off (also tried On with several A/V sync methods)
Best regards, Tepp.Last edited by Tepp; 28 February 2015, 23:47.
Best regards, Tepp.
Originally posted by codesnake View PostWhat content did you try to play? What is video codec? What is audio codec?
For example:
Code:General Unique ID : 233847350371194130521261945311270647459 (0xAFED5C87F52AD8318BAF163BDEA1B6A3) Complete name : \\192.168.0.118\My Passport\Video\Samples\Amerikanskij.pirog.Vse.v.sbore.2012.D.BDRip.1080p.IRONCLUB_sample.mkv Format : Matroska Format version : Version 2 File size : 151 MiB Duration : 1mn 23s Overall bit rate : 15.2 Mbps Movie name : IRONCLUB Encoded date : UTC 2012-08-08 08:24:03 Writing application : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15 Writing library : libebml v1.2.1 + libmatroska v1.1.1 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : [email protected] Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1mn 23s Bit rate : 12.0 Mbps Width : 1 920 pixels Height : 1 040 pixels Display aspect ratio : 1.85:1 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.251 Stream size : 119 MiB (79%) Title : American.Reunion.2012.1080p.BluRay.x264.DTS-HDChina Language : English Default : Yes Forced : Yes Audio #1 ID : 2 Format : DTS Format/Info : Digital Theater Systems Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 1mn 23s Bit rate mode : Constant Bit rate : 768 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossy Delay relative to video : 6ms Stream size : 7.63 MiB (5%) Title : DTS 5.1 @ 768 kbps - BD CEE Language : Russian Default : Yes Forced : Yes Audio #2 ID : 3 Format : DTS Format/Info : Digital Theater Systems Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 1mn 23s Bit rate mode : Constant Bit rate : 1 509 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossy Delay relative to video : 6ms Stream size : 15.0 MiB (10%) Title : DTS 5.1 @ 1536 kbps Language : English Default : No Forced : No Audio #3 ID : 4 Format : AC-3 Format/Info : Audio Coding 3 Format profile : Dolby Digital Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 1mn 23s Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : 27ms Stream size : 1.91 MiB (1%) Title : Commentary 1 Language : English Default : No Forced : No Audio #4 ID : 5 Format : AC-3 Format/Info : Audio Coding 3 Format profile : Dolby Digital Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 1mn 23s Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : 27ms Stream size : 1.91 MiB (1%) Title : Commentary 2 Language : English Default : No Forced : No Audio #5 ID : 6 Format : AC-3 Format/Info : Audio Coding 3 Format profile : Dolby Digital Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 1mn 23s Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : 27ms Stream size : 1.91 MiB (1%) Title : Commentary 3 Language : English Default : No Forced : No Text #1 ID : 7 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : Forced Language : Russian Default : No Forced : No Text #2 ID : 8 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : BD CEE Language : Russian Default : No Forced : No Text #3 ID : 9 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : SDH Language : English Default : No Forced : No Menu 00:00:00.000 : en:00:04:48.746 00:00:07.882 : en:00:08:58.287
Originally posted by codesnake View PostHW decoding does work on M8.
Are there any changes that have to be made to the Kodi or OpenELEC configuration for it to run on all TVs? The devices i am testing on are in Europe. Any options you would suggest i try changing to see if it makes a difference?
Thanks.
There are currently 3521 users online. 0 members and 3521 guests.
