[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
I think u have same box as me mxiii 2g/8g use the openelec s82 5.0 ive tried every thing else
Originally posted by KimKnott View PostSorry for the confusion
I would like to download OpenElec with Kodi 14 for M8 2GB/8GB (Black Square Box).
I am looking for this in OpenElec web site but I cannot find it and I don't want to download some other versions of OpenElec and try with my M8. If someone already using it for the M8 and tried out with 100% test and success please post the link or send me the right file for M8.
Sorry for my bad technical language...
Originally posted by gtvdev View PostWould it take long to update the m8 version to kodi 14.1? this fixed important issues such as the incorrect screen size bug in amlogic devices, streaminfo skipping..etc.
Can someone please advise? i'm not sure if it's a matter of updating the files or manually applying patches.
Originally posted by xoexpireu View Postif its the same mxiii 2g/8g use the openelec s82 5.0 version u will save yourself a lot of time it works great. ive tried everything else thats the best one you may have to download the remote conf and put it in the rite folder though to get remote working
New 5.0.1 Source and the MX2/G18
Has anyone tried to compile the 5.0.1 Source for the MX2?
I got a Error when it was trying to patch the Kernel from
OpenELEC.tv-5.0.1/projects/Amlogic/devices/MX2/patch/linux/add_bootargs_to_device_tree.patch
And just Stops, After looking at it it seems that the meson6_g18.dtd file format may have changed in the Latest Kernel
linux-amlogic-3.10-0e99726.tar.xz
Thomas
Originally posted by tht View PostHas anyone tried to compile the 5.0.1 Source for the MX2?
Thomas
Thomas
He said a few times that he's very busy these days, but I'm sure that he'll release a new version as soon as he can.
Thomas
I don't have a MX2 to test but it builds and should work.
Guest
Originally posted by tracker10 View Posthope this is the right thread i have an m8 android box, and i was trying to install openelec, and it just stuck on the openelec screen can anyone tell how to clear it
Hi all, after reading this and many other threads i'm still unsure of what I can install. I have the M8N android box, what is the latest I can install as it seems different to the M8. I only ever use kodi on my box so not much need for the rest of the android stuff.M8N Quad Core Android 4.4
JustMe v1.5 ported v2
There are currently 2940 users online. 0 members and 2940 guests.
