How to boot my compiled version. With the toothpick reset i got a wrong signature in recovery mode?
[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by yog1 View Postamlogic s802 k200..
open elec work now but not supurted remote control , and wifi not work ?
is it m8? T8? What? What remote? Not enough info for people to help you.
Seems very odd that the wifi is not funictioning correctly as there is lots and lots people using this rom
the remote I understand but again depends what remote your box has.
if you want to flash back to original rom first question did you dump it? If not you will need to locate a new rom to flash but to answer your question of course you can go back.
There are quite a few differant options but need to know what your box is before anyone can try and advise you on your options
Also are you 100% you flashed the correct rom in op?
foz
codesnake I am not kernel expert but I try to activate kernel config CONFIG_MEDIA_SUPPORT=m.
amlogic kernel 3.10.33 or 61 dont activate with tab space (m, n y). it is always CONFIG_MEDIA_SUPPORT=y
Why dont acitvate and which is it related other config. pls need your opinion
it mus be
Code:CONFIG_MEDIA_SUPPORT=m # # Multimedia core support # CONFIG_MEDIA_CAMERA_SUPPORT=y CONFIG_MEDIA_ANALOG_TV_SUPPORT=y CONFIG_MEDIA_DIGITAL_TV_SUPPORT=y CONFIG_MEDIA_RADIO_SUPPORT=y CONFIG_MEDIA_RC_SUPPORT=y CONFIG_MEDIA_CONTROLLER=y CONFIG_VIDEO_DEV=y CONFIG_VIDEO_V4L2_SUBDEV_API=y CONFIG_VIDEO_V4L2=y # CONFIG_VIDEO_ADV_DEBUG is not set # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set CONFIG_VIDEO_TUNER=m CONFIG_V4L2_MEM2MEM_DEV=m CONFIG_VIDEOBUF_GEN=m CONFIG_VIDEOBUF_VMALLOC=m CONFIG_VIDEOBUF_DMA_CONTIG=m CONFIG_VIDEOBUF_DVB=m CONFIG_VIDEOBUF2_CORE=y CONFIG_VIDEOBUF2_MEMOPS=y CONFIG_VIDEOBUF2_DMA_CONTIG=m CONFIG_VIDEOBUF2_VMALLOC=m # CONFIG_VIDEO_V4L2_INT_DEVICE is not set CONFIG_DVB_CORE=m CONFIG_DVB_NET=y CONFIG_TTPCI_EEPROM=m CONFIG_DVB_MAX_ADAPTERS=8 CONFIG_DVB_DYNAMIC_MINORS=y
Originally posted by De Bouwer View PostHey codesnake^^
Any news on a 5.0 kodi build for the M8?
And i have another issue. maybe you can help.
I'm using the ARC to play the sound on my soundbar. but when i turn off my M8 the ARC doesn't work anymore on my other divices.
I tryed any combination of hdmi ports. but nothing helps, i have to leave my M8 on to have ARC working on my other divises.
De Bouwer
Originally posted by De Bouwer View PostWhat link? IT was a question
They dont read, but instead just demand the latest & greayest immediately.
Personally i think that this behaviour will kill the opensource scene in a fast Pace. Shame, but reality unfortunately...
Do rc6 mce infrared remotes work these boxes (with or without a usb ir receiver)?
Also, on the remote that came with my box volume down and volume up buttons are mixed up with home and menu.
They are operating like this
0x10 Volume Down
0x18 Volume Up
0x11 Home
0x4c Menu
But i want to change them to this
0x4c Volume Down
0x11 Volume Up
0x18 Home
0x10 Menu
How do i go about remapping them?
thanksLast edited by moontan6; 07 February 2015, 19:01.
I would like to download OpenElec with Kodi 14 for M8 2GB/8GB (Black Square Box).
I am looking for this in OpenElec web site but I cannot find it and I don't want to download some other versions of OpenElec and try with my M8. If someone already using it for the M8 and tried out with 100% test and success please post the link or send me the right file for M8.
Sorry for my bad technical language...
Originally posted by wackidth View PostIt's easy just download the zip. Unpack, put the three files on a sd card.
Push in the reset button with a toothpick in the av hole. Plug in the power wait to secs. And release the reset button.
That's it.....
No issues for me on RC3....(4.97.3)
Guest
Originally posted by KimKnott View PostI am sorry to ask this question. Where did you find that OpenElec with Kodi RC3 for M8 box?
Please do some research... And look in the OP (translation Opening Post).
There you will find versions.
There are currently 1558 users online. 0 members and 1558 guests.
