Thank youuuu!!!
[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Testing this new version on my M8 box.. All is working smooth...
i see now when playing music the screensaver is acting normal.. not going fast and slow.. but nice at one speed..
There is for me now just one litle problem.. which was also in previous version. I have no audio output on AV Analog port..
Is there a way to get this working?
Regards and keep up the great work as i really love it!!
Update process
Originally posted by codesnake View PostOpenELEC 5.0.3 for Amlogic-based TV-boxes is available now. See the first post in this topic for more details.
Hi @Codesnake,
just read your post, many many thanks again, I understood you were very busy last weeks.
I will download tonight and test it.
Just for my (and others?) information, as I am not a software specialist:
AM I right if I ask that every version update from Openelec involve a complete rebuild of your software from your side?
How many hours does this take you each time (on average)?
Are you planning to keep up with the updates from OE for a long time?
Cheers!
Guest
Thanks Codesnake...
For your time and effort on this great solution for our M8's
Really appreciated.
Guest
Hi Codesnake,
I have problems with the HDMI handshake on a 2014 Panasonic TV.
The screen keeps black when I start up. Sometimes I have screen but all blue-ish.
What can I try to fix this?
Didn't have these problem on 4.97.3
Hello Codesnake,
First, thank you for your hard work on this rom. But i have some problems.
Problem, while playing streaming movies over the internet, or movies from the hard disk. The sound drops out periodically with DTS, DD, AAC audio tracks with auto framerate/resolution switching to 24p Movies in Openelec 5.0.3 for M8 2gb
Wired internet connection is lost after a while. Did a clean install and then have tested this ROM. Wanted to let you know. I'm back to your old ROM.
Greetings,
ShinysidewinderLast edited by shinysidewinder; 16 February 2015, 20:31.
Originally posted by Jönke View PostThanks Codesnake for 23,976 fps fix , much wanted
My Problem is solved for now. Set to software decoding in video system settings. Now have nicely 1920-1080@24hz in movies without audio stutter with DTS. DD, AAC, and Stereo passthrough.
Setup:
M8 2gb
Onkyo TX-SR608
TV Samsung LE40B650 Full HD
Weird, i think it seems to be a problem with Hardware decoding Amcodec in Openelec 5.0.3 for M8 2gb. Problem is the same with and under 5.0.3 Kerber and Codesnake builds.
There are currently 1999 users online. 1 members and 1998 guests.
