I have read about this exact issue. I believe it had something to do with the way the Panasonic handles the hdmi handshake and i know of one case where Panasonic had offered to replace the TV...
[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by trapdoor_howie View PostTrying to update from 4.21 to the 5.03
tried putting the tar in the update folder and toothpick method
both time update appears to work,
but on first normal boot stops on the openelec logo centre screen
and a text message top left
starting debugging shell... type exit to quit#
cant access tty; job controlled turned off
any hints
thanks in advance
Look two posts above your original post and try that method.
vigica c60s
Hi all
i have this box http://www.aliexpress.com/item/2015-...009187420.html
I would like to install openelec on it , can i ?
will i be able to use dvb-s2 ?
does openelec replace android ?
is it risky ?
thank you for your help
regards
Originally posted by taki View Postdo anybody use dvb tuner with tvheadend on openelec. can you watch any problem h264 HD channels with openelec. I have problem h264 mpeg4 hd channels on openelec.
I have any problem 0-6 mb/s hd amc-h264 channels but 6-20mb/s channels stutter every 20 second. that may be based amcodech or usb tuner connect host speed or cpu?Code:DEBUG: PVRManager - bool PVR::CPVRManager::PerformChannelSwitch(PVR::CPVRChannel&, bool) - switching to channel 'TRT HABER HD' 02:36:08 T:1936608240 INFO: AddOnLog: Tvheadend HTSP Client: SwitchChannel - changing to channel 'TRT HABER HD' 02:36:08 T:1936608240 INFO: AddOnLog: Tvheadend HTSP Client: SendUnsubscribe - unsubscribe from subscription 2 02:36:08 T:1928223608 DEBUG: CAMLCodec::SetSpeed, speed(0) 02:36:08 T:1866097440 INFO: AddOnLog: Tvheadend HTSP Client: ParseSubscriptionStop - subscription ended on adapter Montage Technology DS3000 : DVB-S #0 02:36:08 T:1936608240 INFO: AddOnLog: Tvheadend HTSP Client: SendSubscribe - subscribe to channel '832160303', subscription 3 02:36:08 T:1936608240 DEBUG: AddOnLog: Tvheadend HTSP Client: SendSubscribe - new subscription for channel 14912203 (3) 02:36:08 T:1936608240 DEBUG: Loading settings for pvr://channels/tv/Tüm Kanallar/303.pvr 02:36:08 T:1936608240 DEBUG: CPVRChannelGroup - bool PVR::CPVRChannelGroup::Persist() - persisting channel group 'HDTV' with 13 channels 02:36:08 T:1782591720 DEBUG: ------ Window Deinit (VideoOSD.xml) ------ 02:36:08 T:1936608240 NOTICE: PVRManager - bool PVR::CPVRManager::PerformChannelSwitch(PVR::CPVRChannel&, bool) - switched to channel 'TRT HABER HD' 02:36:08 T:1861550536 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc 02:36:08 T:1861550536 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop 02:36:08 T:1861550536 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc 02:36:08 T:1861550536 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay 02:36:08 T:1936608240 NOTICE: Creating Demuxer 02:36:08 T:1936608240 DEBUG: CDVDPlayer::SetCaching - caching state 2 02:36:08 T:1928223608 DEBUG: CAMLCodec::SetSpeed, speed(0) 02:36:08 T:1782591720 DEBUG: ------ Window Init (DialogSeekBar.xml) ------ 02:36:08 T:1782591720 DEBUG: Window DialogSeekBar.xml was already loaded 02:36:08 T:1782591720 DEBUG: Alloc resources: 0.21m 02:36:10 T:1866097440 DEBUG: AddOnLog: Tvheadend HTSP Client: ProcessMessage - Unmapped action recieved 'subscriptionGrace' 02:36:11 T:1866097440 DEBUG: AddOnLog: Tvheadend HTSP Client: ParseSubscriptionStart - id: 1, type: H264, codec: 28 02:36:11 T:1866097440 DEBUG: AddOnLog: Tvheadend HTSP Client: ParseSubscriptionStart - id: 2, type: MPEG2AUDIO, codec: 86016 02:36:11 T:1866097440 DEBUG: AddOnLog: Tvheadend HTSP Client: ParseSubscriptionStart - id: 3, type: TELETEXT, codec: 94215 02:36:11 T:1866097440 INFO: AddOnLog: Tvheadend HTSP Client: ParseSubscriptionStart - subscription started on adapter Montage Technology DS3000 : DVB-S #0, mux 11054V, network turksat, provider TRT, service TRT HABER HD 02:36:11 T:1936608240 DEBUG: CDVDDemuxPVRClient::RequestStreams(): added/updated stream 0:1 with codec_id 28 02:36:11 T:1936608240 DEBUG: CDVDDemuxPVRClient::RequestStreams(): added/updated stream 1:2 with codec_id 86016 02:36:11 T:1936608240 DEBUG: CDVDDemuxPVRClient::RequestStreams(): added/updated stream 2:3 with codec_id 94215 02:36:11 T:1936608240 NOTICE: Opening stream: 0 source: 256 02:36:11 T:1936608240 NOTICE: Creating video codec with codec id: 28 02:36:11 T:1936608240 DEBUG: CDVDFactoryCodec: compiled in hardware support: AMCodec:yes MediaCodec:yes OpenMax:no libstagefright:yes RKlibstagefright:yes VDPAU:no VAAPI:no iMXVPU:no 02:36:11 T:1936608240 DEBUG: FactoryCodec - Video: amcodec - Opening 02:36:11 T:1936608240 INFO: DVDVideoCodecAmlogic: Opened Amlogic Codec 02:36:11 T:1936608240 DEBUG: FactoryCodec - Video: am-h264 - Opened 02:36:11 T:1928223608 DEBUG: CAMLCodec::CloseDecoder 02:36:11 T:1803998552 DEBUG: CAMLCodec::Process Stopped 02:36:11 T:1803998552 DEBUG: Thread CAMLCodec 1803998552 terminating 02:36:11 T:1936608240 NOTICE: Opening stream: 1 source: 256 02:36:11 T:1936608240 NOTICE: Finding audio codec for: 86016 02:36:11 T:1936608240 DEBUG: FactoryCodec - Audio: passthrough - Opening 02:36:11 T:1936608240 DEBUG: FactoryCodec - Audio: passthrough - Failed 02:36:11 T:1936608240 DEBUG: FactoryCodec - Audio: FFmpeg - Opening 02:36:11 T:1936608240 DEBUG: FactoryCodec - Audio: FFmpeg - Opened 02:36:11 T:1936608240 NOTICE: Opening stream: 2 source: 256 02:36:11 T:1936608240 DEBUG: void CDVDDemuxPVRClient::ParsePacket(DemuxPacket*) - {1} iSampleRate changed from 3 to 48000 02:36:11 T:1936608240 NOTICE: Opening stream: 1 source: 256 02:36:11 T:1936608240 NOTICE: Finding audio codec for: 86016 02:36:11 T:1936608240 DEBUG: FactoryCodec - Audio: passthrough - Opening 02:36:11 T:1936608240 DEBUG: FactoryCodec - Audio: passthrough - Failed 02:36:11 T:1936608240 DEBUG: FactoryCodec - Audio: FFmpeg - Opening 02:36:11 T:1936608240 DEBUG: FactoryCodec - Audio: FFmpeg - Opened 02:36:11 T:1927676016 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_RESYNC(-4960000.000000, 1) 02:36:11 T:1927676016 NOTICE: Creating audio stream (codec id: 86016, channels: 2, sample rate: 48000, no pass-through) 02:36:11 T:1804227936 DEBUG: CActiveAE::DiscardStream - audio stream deleted 02:36:11 T:1804227936 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted 02:36:11 T:1927676016 DEBUG: Previous line repeats 1 times. 02:36:11 T:1927676016 DEBUG: CDVDPlayerAudio:: synctype set to 0: clock feedback 02:36:11 T:1936608240 DEBUG: CDVDPlayer::HandleMessages - player started 1 02:36:11 T:1936608240 DEBUG: void CDVDDemuxPVRClient::ParsePacket(DemuxPacket*) - {0} profile changed from -99 to 100 02:36:11 T:1936608240 DEBUG: void CDVDDemuxPVRClient::ParsePacket(DemuxPacket*) - {0} level changed from -99 to 40 02:36:11 T:1936608240 NOTICE: Opening stream: 0 source: 256 02:36:11 T:1936608240 NOTICE: Creating video codec with codec id: 28 02:36:11 T:1936608240 DEBUG: CDVDFactoryCodec: compiled in hardware support: AMCodec:yes MediaCodec:yes OpenMax:no libstagefright:yes RKlibstagefright:yes VDPAU:no VAAPI:no iMXVPU:no 02:36:11 T:1936608240 DEBUG: FactoryCodec - Video: amcodec - Opening 02:36:11 T:1936608240 INFO: DVDVideoCodecAmlogic: Opened Amlogic Codec 02:36:11 T:1936608240 DEBUG: FactoryCodec - Video: am-h264 - Opened 02:36:11 T:1928223608 DEBUG: CAMLCodec::CloseDecoder 02:36:12 T:1936608240 DEBUG: set caching from pvr to done. audio (1) = 17. video (1) = 13 02:36:12 T:1936608240 DEBUG: CDVDPlayer::SetCaching - caching state 0 02:36:12 T:1927676016 DEBUG: CDVDClock::Discontinuity - CDVDPlayerAudio::HandleSyncError1 - was:-5011701.333333, should be:-5013682.333751, error:-1981.000417 02:36:12 T:1928223608 DEBUG: CAMLCodec::SetSpeed, speed(1000) 02:36:12 T:1928223608 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_RESYNC(-3539745.000000, 0) 02:36:12 T:1928223608 DEBUG: CAMLCodec::OpenDecoder, android version 19 02:36:12 T:1928223608 DEBUG: codecid_to_vformat, id(28) -> vformat(2) 02:36:12 T:1928223608 DEBUG: codec_tag_to_vdec_type, codec_tag(28) -> vdec_type(4) 02:36:12 T:1928223608 DEBUG: CAMLCodec::OpenDecoder hints.width(1920), hints.height(1080), hints.codec(28), hints.codec_tag(0), hints.pid(1) 02:36:12 T:1928223608 DEBUG: CAMLCodec::OpenDecoder hints.fpsrate(1000000), hints.fpsscale(40000), hints.rfpsrate(0), hints.rfpsscale(0), video_rate(3840) 02:36:12 T:1928223608 DEBUG: CAMLCodec::OpenDecoder hints.aspect(1.777778), video_ratio.num(1), video_ratio.den(1) 02:36:12 T:1928223608 DEBUG: CAMLCodec::OpenDecoder hints.orientation(0), hints.forced_aspect(0), hints.extrasize(148) 02:36:12 T:1782591720 DEBUG: ------ Window Deinit (DialogSeekBar.xml) ------ 02:36:12 T:1928223608 DEBUG: ERROR:write header failed! 02:36:12 T:1928223608 DEBUG: [int write_av_packet(am_private_t*, am_packet_t*)]write header failed! 02:36:12 T:1928223608 DEBUG: CAMLCodec::SetSpeed, speed(1000) 02:36:12 T:1928223608 DEBUG: ERROR check in pts error! 02:36:12 T:1928223608 DEBUG: check in pts failed 02:36:12 T:1928223608 DEBUG: ERROR check in pts error! 02:36:12 T:1928223608 DEBUG: check in pts failed 02:36:12 T:1928223608 DEBUG: ERROR check in pts error! 02:36:12 T:1928223608 DEBUG: check in pts failed 02:36:12 T:1928223608 DEBUG: ERROR check in pts error! 02:36:12 T:1928223608 DEBUG: check in pts failed 02:36:12 T:1928223608 DEBUG: ERROR check in pts error! 02:36:12 T:1928223608 DEBUG: check in pts failed 02:36:12 T:1928223608 DEBUG: ERROR check in pts error! 02:36:12 T:1928223608 DEBUG: check in pts failed 02:36:12 T:1928223608 DEBUG: ERROR check in pts error! 02:36:19 T:1928223608 DEBUG: ERROR check in pts error! 02:36:19 T:1928223608 DEBUG: check in pts failed 02:36:19 T:1928223608 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available 02:36:19 T:1928223608 DEBUG: ERROR check in pts error! 02:36:19 T:1928223608 DEBUG: check in pts failed
Openelec 5.0.3, kodi 14.1, kernel 3.10.61 dvb-s2 sat version
for VS-IP015, the image under the SD card
- Base Openelec 5.0.3, kodi 14.1, kernel 3.10.61
- Working wi-fi
- Optimization of channel switching
- Tvh client
oe_vitmod_1.4.img.zip
service.multimedia.tvheadend-4.3.9.zipyadi.sk
«Сомалійська Наноелектроника та Космонавтика»- VS-IP015 - Android Sat Receiver - g18ref_th2
- WeTek Play - Android Sat Receiver - g18ref
Guest
Originally posted by osdieman View Post@ Codesnake : Thank you for your nice work
Thank you for this great software for my M8 Box.. so far most things working fine.. but i have one little problem..
For some reason i cannot get the audio from the 3.5mm jack plug.. the reason i need this is because i use a small pc speaker system..
The box does send audio over hdmi to the tv but this sound is not nice so i want to send it to my speaker system..
My bad luck is my tv has no audio output..
So is there a way to enable the audio out on the 3.5mm jack??
I also found out when play music the screensaver OpenGL Spectum is running fast and slow.. so not running stable..
Regards Osdieman
Working on my box is well via HDMI, but when I connect a monitor without speaker, I have any sound via a/v analogue output(3.5 mm).
This is the log of aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: AMLM8AUDIO [AML-M8AUDIO], device 0: AML PCM AML-M8-0 []
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: AMLM8AUDIO [AML-M8AUDIO], device 1: SPDIF PCM dit-hifi-1 []
Subdevices: 1/1
I have edited /storage/.config/asounf.conf as below.
pcm.!default { type hw card 0 device 0 format S16_LE }
ctl.!default { type hw card 0 }
However, didn't work. Would anyone give me information related this issue?
Once the a/v analogue output works properly, after just flashing the firmware with SD card and edit /storage/.config/asound.conf as device 1 -> device 0 . It can be working well unless power off(not reboot).
I think the sound control by ALSA is only available in warm-booting(reboot via ssh or xbmc reboot) without kernel load. Once the system is powered off then on, device 0 ( a/v analogue output ) won't work.
Originally posted by d3xt3r View PostHi code,first congratulations and thanks for your work
Only I have a problem with the server allmyvideos.net and vidspot, I have video but no sound. Is it normal? Is there a solution?
Thanks and sorry for my english
Originally posted by JinKim View PostSame as me as well. I have no sound with A/V output. My box is M8 S802 k200a called OTT TV BOX.I flashed OpenELEC for Amlogic 5.0 with Kodi 14.1 Helix on M8.
Subdevices: 0/1
Subdevices: 1/1
There are currently 1908 users online. 0 members and 1908 guests.
