[ROM] OpenELEC for Amlogic-based TV boxes (M8, MXQ, TV110, MX2/G18)
Originally posted by nukeybrown View Postthink ive worked out the cec edid issue, i have 2 boxes m8n and m8, m8n works for resolution change but m8 doesnt even when using the same version of openelec.
Thanks codesnake.
Update in wifi working 5g ok, more testing
Any chance to get scroll wheel working with mouse ?
Cheers
Originally posted by codesnake View PostOpenELEC for Amlogic 5.0 Beta3 is now available. See the first post in this topic for more details.
Originally posted by warken View PostThanks codsnake!
Tried Beta3 on MXIII 2G:
- no wifi
- stock RC not working
but good thing, HEVC (h.265) working very well on my MXIII without stuttering.
I have a theory why cec and screen resolution isnt working on some boxes and working on others. The recovery files being used for the build are sourced from stane who is using m8n files . If you have a m8 box with no N on the bottom this could be why its not working , i think the m8 has a different recovery file etc
just a theory im sure codesnake should be able to clarify if this could be a cause.
possibly different board revisions have diff, gpio locations etc
if i flash the box direct from memory card i get debugging shell error tty job control turned off but when i flash the box using the built in recovery it works and boots up no issue.
Originally posted by nukeybrown View PostI have a theory why cec and screen resolution isnt working on some boxes and working on others. The recovery files being used for the build are sourced from stane who is using m8n files . If you have a m8 box with no N on the bottom this could be why its not working , i think the m8 has a different recovery file etc
There are currently 2257 users online. 1 members and 2256 guests.
